DK5010 Keep Breaking Lights on the ROPS--Any Ideas?
   / DK5010 Keep Breaking Lights on the ROPS--Any Ideas? #11
Move them to the inside of the ROPS. Have done this on 3 tractors and haven't broken any mounted on the inside.
Ralph
   / DK5010 Keep Breaking Lights on the ROPS--Any Ideas? #12
   / DK5010 Keep Breaking Lights on the ROPS--Any Ideas? #13
There were some Kioti light guards on Ebay that looked like a 4 inch section of pipe that covered the light and bolted to the ROPS.
Ralph
so you cut off and rewelded and then repainted?
   / DK5010 Keep Breaking Lights on the ROPS--Any Ideas? #16
First off, do you even need them? Do you ever go on public roads?
If you do, consider some kind of LED marker light with a narrow profile and flat back that can be mounted TO the roll bar instead of to the side of it. Strong adhesive means no screw holes. Just wire them to the brake or signal circuits as necessary.
   / DK5010 Keep Breaking Lights on the ROPS--Any Ideas? #17
Light guards are easy to make if you're handy and have access to a welder. I don't have any on my cab tractor, but I made two for my JD2305 because I kept having the same issue as you. Of course, I cut all the limbs AFTER I busted up my lights from getting hit.
A few pieces of steel bar stock bent or cut/welded should work.
   / DK5010 Keep Breaking Lights on the ROPS--Any Ideas? #18
I bet those low hanging limbs are flinging ticks at you!. not good!.:eek:
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A56138)
2003 VOLVO VNL...
IRanch Dump Hopper (A55851)
IRanch Dump Hopper...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A55852)
2012 Freightliner...
BUYER'S PREMIUM INFO LOT NUMBER 2 (A53084)
BUYER'S PREMIUM...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
2020 BOBCAT E32 EXCAVATOR (A52707)
2020 BOBCAT E32...
