DK45SE Starter doing machine gun imitation
   / DK45SE Starter doing machine gun imitation
Ok, so was going to take a video and the darn thing started right up. I really don't like inconsistent electrical issues. Any thoughts on things I should have on hand in case this shows up again?
   / DK45SE Starter doing machine gun imitation #12
I would go ahead and remove the battery terminals and clean them and the post. Could still be an intermittent connection that has now burnt through the corrosion but will return.
   / DK45SE Starter doing machine gun imitation #13
Was your battery charger still connected when the tractor finally started? Looking closely at your photo of the volt/ohmmeter probes, they may not have been in good contact with the battery posts when you took the reading. If your battery is truly at 10 V and your charger/starter is disconnected there's no way you could have started the tractor. As Randy suggests, I'd next pull and clean the battery terminals and the posts, and check for corrosion/discoloration of the copper wire at the terminal ends. Since the battery is practically new, and unless the terminals were not properly tightened a few months ago, I doubt it's a corrosion problem. Take another reading of your battery voltage. And check the belt tension.
With the simple things ruled out, you can then move on to checking charging system if necessary. Can do some of that with your voltmeter and the tractor running. I'm no sparky, but I can help a bit with that.
I left the charger on it for an hour, took them off and did another voltage check. Came out to 13.3V. Tractor fired up like normal, so will keep an eye on it for now. During the winter we didn't get much snow so it didn't get used much. Spring now will be back on mowing duty, tree limb pickup/haul, and field tilling. So feeling better about it now. Did an oil and fuel filter change while the battery was charging.
I think @Threepoint you were correct that the hammering was the solenoid not getting enough voltage. Thanks all for the advice!
   / DK45SE Starter doing machine gun imitation #15
Take the battery into auto shop and have it load tested. If its a walmart battery…simply throw it out.
   / DK45SE Starter doing machine gun imitation #16
Hook up a 2amp battery maintainer 24/7…
edit: Meant to say “after battery replacement” as it’s too late for the current battery.
   / DK45SE Starter doing machine gun imitation #17
Thats all good and well, but dont expect a 2 amp charger to restore a dead battery. You can maintain a 700-1000 amp battery with one, but not charge a dead one. Ive seen too many batteries that can read good without a load, but die right out under starting load.
   / DK45SE Starter doing machine gun imitation #18
just always act like you’re going to take a video when you want to start it, and it’ll get scared and start right up ……. (ha ha)
   / DK45SE Starter doing machine gun imitation #19
My OEM original battery in my DK45S would turn on the dash light go through pre-heat and loose everything when the starter was hit. Loose dash lights until the key was cycled back off and on again Your can put the charger on that battery. Flip the charge swtich on and off like turning on and off a key, and it would start for a week. That battery also tested with 12 volts from the positive terminal to the plastic battery case. Faulty battery that if you put it on the charger prior to testing would test good. Had to test while in failed position due to an intermittent bad cell.
   / DK45SE Starter doing machine gun imitation #20
A poor battery connection can also cause it. The load created by the starter cause a voltage drop that caused the starter solenoid to disengage temporarily, and then when the load drops the voltage returns which allowed the starter solenoid to re-engage. Rinse and repeat.
That's what mine was, although the positive connector looked OK, there was a bit of fuzz growing out from under the wire insulation. I think the connector, wasn't all lead, and there was some kind of galvanic/oxidization going on between it and the copper. I cut the positive wire back to nice looking copper and got a good connector at the hardware store and its been fine ever since.
2010 Toro Workman MD Utility Cart (A55973)
2010 Toro Workman...
2007 Yamaha Rhino 660 (A56435)
2007 Yamaha Rhino...
Deere 333G (A53317)
Deere 333G (A53317)
BUCKET TRUCK (A56858)
2018 Ariens Ikon 52in Zero Turn Commercial Mower (A56857)
2018 Ariens Ikon...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
