DK45SE HST Socket Question
/ DK45SE HST Socket Question #1
taw1126
Houston, TX
Kioti DK45SE HST
All-
I tried the search function for this but came up empty.
Got most of the way through my 50 hour maintenance last week...everything but the transmission / hydraulic fluid & filters. Figured out that I didn't have a socket large enough to remove the drain plugs and was hoping someone can tell me what size I need to buy since the tractor is 100+ miles away. For that matter, if anyone can tell me the sizes I need above 26mm I'd really appreciate it.
Thanks in advance for your help.
P.S.- for anyone who may be considering a Kioti utility tractor, I've got nothing but rave reviews for mine. It has exceeded all expectations and I'm very happy that I "stumbled" onto them while I was comparing Mahindra, Deere, Kubota, and New Holland. I'm sure those are all good too but I can't imagine they come close to Kioti's bang for the buck.
/ DK45SE HST Socket Question #2
Just completed my 300 hour change, transmission and engine, and a 15/16 fits the axle drains and a 1 3/16 works on the main drain. Metric would be 24 and 30. I caught the axle one at a time in a three gal bucket and had to use two buckets for the main. amount drained was a little over 2 1/2 from the axle and almost 5 from the main. Hope this helps.
Yes, helps very much. Now I think the only issues I have to deal with are removing the filters (just going by everything I've read about factory over-tight filters) and disposing of the used fluid. Auto place close to our property has got new rules on what they will take, and have a limit of 5 gallons a day.
Thanks again for your help.
/ DK45SE HST Socket Question #4
I bought a 5 gal blue kerosene jug and then use a couple of three gal open buckets. Those three held all of the old oil and then pour the old oil back into the new empty containers. I bought new oil in both a 5 gal and 2 1/2 gal containers. The 2 1/2 are a lot easier to pour out of. Be sure to tack the vent plug out above the dipstick.
/ DK45SE HST Socket Question #5
If I remember correctly. The drain plugs practically u stewed by hand. Not very tight at all. The assemblers were probably tired from overtightning the hydro filters lol. I'm sure a crescent wrench would loosen them quite easily with no rounding of the edges.
/ DK45SE HST Socket Question #6
Yes, you want to be very careful not to strip the aluminum threads in the oil pan. I use a small crescent wrench made by Channellock that opens wide and has fairly narrow jaws. I find it easier to judge the firm, but not loose torque to tighten the oil drain plugs.
I cut the bottom third off a 30 gallon oil drum so it just fits under the tractor to handle hydraulic fluid changes. It lets me drain it all at once and then transfer that oil to a storage barrel.
I did notice that with the front axle...was very surprised at how loose the drain, fill, and check plugs were installed. Oil pan drains were pretty snug, but I didn't even check the hydraulic drain plugs (other than having my kid try to make a 26mm socket fit on what was apparently a 30mm plug).
Having never done a hydraulic fluid service before...will the "spent" fluid look just like used motor oil?
Thanks for the ongoing help.
/ DK45SE HST Socket Question #8
My hydro fluid looked new, very clear.
/ DK45SE HST Socket Question #9
1-1/8" is the same as 30mm as I recall.
sort of like 7/8" is basically the same as 22mm.
/ DK45SE HST Socket Question #10
The fluid will not be any where near as black as used motor oil.
/ DK45SE HST Socket Question #11
There is no soot to be had in Hydraulic fluid.
/ DK45SE HST Socket Question #12
At 400 hours (350 hours since hydro oil change), my hydro oil was almost clear but with a silt (probably from seals) and some meal flakes that settled.
Thanks to all. The local recycle place is getting picky (or worried) about what they're accepting so that's why I was asking. Shouldn't be a reason they can't take it...probably will be fine with anything that doesn't look like antifreeze and no reason I can think of that hydraulic fluid wouldn't recycle.
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
2001 MACK RD688S ROLL OFF TRUCK (A65643)
2001 MACK RD688S...
6' Picnic Table (A66408)
6' Picnic Table...
Duratech HD 8 Tub Grinder (A62613)
Duratech HD 8 Tub...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
