3-Point Hitch DK45S and 6ft Modern Brush Hog
   / DK45S and 6ft Modern Brush Hog #1
joshgrammer01
Kioti dk45s
If a 6ft brush hog is attached to a DK45S correctly, should the brush hog come completely off the ground when raising the 3 point to it highest position?
   / DK45S and 6ft Modern Brush Hog #2
Depends on how you have the toplink set. Basically you should be able to lift the mower all the way off the ground but if the top link is set really long perhaps the geometry won't allow it. Certainly the 3pt lift capacity should not be an issue.
   / DK45S and 6ft Modern Brush Hog #3
Shorten the top link in the floating hitch until the hitch hangs at about a 45 degree angle. SLOWLY lift the 3-point and shorten the top link if necessary. Be careful that the PTO Drive-line doesn't bottom out on the top of the deck before you get to the raised position.
   / DK45S and 6ft Modern Brush Hog #4
My rotary cutter is about 18 inches off (and parallel to) the ground when fully raised. Older John Deere model. 2006 Kioti DK45C
The top link was in the highest position. I moved it to the lowest position and now i am getting about 10 inches of lift measuring off the wheel of the rotary cutter to the ground. Thanks for the help.
   / DK45S and 6ft Modern Brush Hog #6
I'd expect a little more clearance. Is the toplink itself mostly extended or not. Michigan Iron gave good advice on how to adjust it.
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2015 Ford Taurus (A51694)
2015 Ford Taurus...
JOHN DEERE WHEEL LOADER 71" FORKS (A51246)
JOHN DEERE WHEEL...
2021 KUBOTA SVL75-2 SKID STEER (A51246)
2021 KUBOTA...
2014 PETERBILT 388 AUTO TRANSPORTER (A52576)
2014 PETERBILT 388...
