DK4510 front axel oil level/fluid
   / DK4510 front axel oil level/fluid #1
Nancy Kowalski
Kioti DK4510HS
Hi there. I just had my tractor split in two to fix a faulty clutch seal under warranty. Checked all fluids today and noticed front axel oil below dipstick mark. Would they have changed this (and not properly filled) as part of a splitting operation?
What fluid should I put in? Get from dealer? Does this need to be warm to check?
Nancy
   / DK4510 front axel oil level/fluid #2
The older models use either tractor fluid (e.g. transmission stuff) or gear oil, either is OK. But check your owners' manual for your newer model.
The front axle can be tricky. In addition to needing to be level when you check, air gets trapped in the gears and you need to drive the tractor to get the air out and then recheck the level.
Swict 72" Bucket (A50121)
Swict 72" Bucket...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2014 Kia Optima Hybrid Sedan (A50324)
2014 Kia Optima...
Hesston 1120 Haybine (A50774)
Hesston 1120...
2 Axle Trailer (TITLE) (A50774)
2 Axle Trailer...
