DK4510 2485 Backhoe Lacking power
   / DK4510 2485 Backhoe Lacking power #1
Grant1
Bronze Member
Middleburg Fl
Kioti CK30, Kioti DK45hst
I have a DK4510 with a 2485 backhoe attached which seems to lack power on breakout force. I have also owned a ck30 with a 2375 that actually seemed to have more power with the backhoe. I really noticed this yesterday trying to remove palmettos running at 1800 rpms. . I also could not pick up the corner of a 4" concrete slab driveway. The backhoe digs dirt fine but really seems to lack the power on other uses. Thanks in advance for any advice
   / DK4510 2485 Backhoe Lacking power #2
If your loader works fine, I would assume the tractor hydraulics and its pressure relief valve are set right. The bh itself does have its own pressure relief valve. You'd have to attach a gauge to a hyd line, like the dipper or bucket curl cylinder on the bh, and see what you get.
   / DK4510 2485 Backhoe Lacking power #3
I have a similar issue. Had a CK 25 w/2475 backhoe. It seemed to work fine. In 2012, I traded for a DK 40SE w/cab and a 2485 Backhoe. I find that the boom seems "weaker" than the smaller hoe was. I had the dealer come out and he put a guage on the cylinder. Pressure was almost 3,000 lb, so we put the return line directly into the filler tube. (there's a kit for that) It is better, but it's still just doesn't "feel" right.
Agco 4227 4 Star Tedder (A50774)
Agco 4227 4 Star...
New Holland 900 Chopper (A50774)
New Holland 900...
Same Row Crop 85 (A50121)
Same Row Crop 85...
International 284 Tractor (RUNS) (A50774)
International 284...
2010 Cadillac SRX SUV (A50324)
2010 Cadillac SRX...
2025 Kivel 48in Tractor Loader Fork Attachment (A50322)
2025 Kivel 48in...
