DK45 smokes white at all times
   / DK45 smokes white at all times #12
Get it knocking and loosen an injector line AT THE INJECTOR and listen for the knock to go away..if it’s still there, tighten the line and move to the next one..
Your trying to narrow it down to A cylinder.. good luck
I'll try that tonight.
My mechanic said may be head gasket (after seeing the video). What's everyone's opinion on that? It's a 2h haul to get it to them, so i def, want to do as much work myself as I can.
I couldn't find either injectors online for this model, anyone know where one might look for them (in case it's them). The engine is a 4a22.
Awesome. Thanks for the offer.
I assume I'd best send them all at the same time, just to make sure right?
I'll report back later today about the findings when cracking the lines.
Cracked the injectors just now.
Cold and rainy day here, so it was smoking pretty good already.
Cracked #1: almost stalled right away
Cracked #2: no major change
Cracked #3: started stalling
Cracked #4: no major change
All four lines had diesel squirt out though.
   / DK45 smokes white at all times #18
U WANT to hear a change when u loosen the line..
So 2 & 4 seem to b the problem..
But get them all checked..
U can reach me directly at::
thepumpguysc@aol.com
Perfect. Just sent you a dm, but I'll send you an email as well, that's easier.
   / DK45 smokes white at all times #20
Badmonkey, maybe GBBBBB could have said it more polite but he did make a valid point. When serial number plate is missing it does make one wonder if it is or was stolen. Yes some get torn off totally by accident. But missing or defaced serial numbers at least to me is a cause of concern. Again there can be a valid reason for that and not sure you had posted anywhere before his comment that you had the paperwork.
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2015 FREIGHTLINER...
Fuel Tank (A51573)
Fuel Tank (A51573)
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2020 BOBCAT T76 R-SERIES SKID STEER (A51246)
2020 BOBCAT T76...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
