DK45 PTO problem
   / DK45 PTO problem #1
wyguy01
gillette, wyoming
case 1070, kubota 7040, mahindra 6520
PTO will not kick out unless releay in fuse box is pulled any ideas ?
   / DK45 PTO problem #2
Well it is electric over hydraulic.. so I would pull the plug on the PTO solenoid and see if the problem is in the switch or is the solenoid sticking, or what..
Do you have the workshop manual.. If not and you intend to fix it yourself, you will sure need it. It is kinda complicated especially with the auto pto microswitch in the fender actuated by the position control lift handle. by the way make sure the auto pto switch is turned off.. I assume you did that already.
   / DK45 PTO problem #3
Looking at a DK45-50 schematic, if the PTO push button and the auto switch (with 3-point raised) won't stop the PTO , I think the actual relay must be the problem.
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
43006 (A51691)
43006 (A51691)
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A52472)
2008 V.E...
Cummins 7HGJAE-2132 Generator (A50121)
Cummins...
