DK45 data wanted
/ DK45 data wanted #1
ElDorado
Adirondack Park
Kioti DK35
Guys, I have been a regular reader for years. The info I have learned from y'all is remarkable. I have been waiting to re-enter the tractor market until the right tractor comes available, at the right time, for the right price. Well I think I found the tractor, it is a 2003 DK45 with KL249 and a Woods BH9000. Here are my questions: 1) KL249 - what are specs? Some say it is same as Rhino 2049, is this true? 2) BH9000 - really want a thumb. Any suggestions? It looks like Michigan Iron does nice work. Anyone have his thumb?
Appreciate,
E!
/ DK45 data wanted #2
Welcome ElDorado.
Maybe one of the dealers will chime in with info on the KL249. Both the loader and tractor are now out of production as far as I know. I cannot recall if anyone active on the board has a DK45 (lots of DK45S and newer models but not that one).
Based on his involvement here, I'd personally trust Michigan Iron to produce a good thumb at a fair price and buy one sight unseen. I would however think through why you want the thumb. I have one on my backhoe and find it not nearly as useful as I thought it would be. For some special applications it is great but for general digging duty it gets in the way as much as it helps.
/ DK45 data wanted
Island, Thanks for the quick response. I emailed Michigan Iron and they seem willing to work something out regarding a thumb.
I am hoping you are right that a dealer, like Rick Wallace, can point me toward data on the KL249. My Kubota dealer has accused me of analysis paralysis. Guilty as charged!
The DK45 is a 2003 so to speak (not wanting open up the year discussion with tractors). I guess I am assuming the KL249 is also a 2003. I may be under water on this. Maybe the dealer had it on the lot when he sold the tractor originally.
I am worried about the KL249 as it applies to some issues I have read about Kioti brand loaders. Is the KL249 one of "those" loaders. I don't want to buy and find out I have a sub par loader, then what?
E!
/ DK45 data wanted #4
E!
I'd ask Michigan Iron if you are going to be talking to him about the BH thumb anyway. He seems quite knowledgable too.
As far as I know the KL249 has not be a problem loader. The issues you are referring to were with the KL120/130 loaders built in Korea. I don't know if the KL249 is a Rhino or another US manufacturer (cannot recall the acronym right now) but I believe it is a US built loader from a good company. Obviously use history and maintenance would be issues with any used loader but I don't think you need to worry about it being a bad design or build.
/ DK45 data wanted #5
Here are some published psecs for the KL249 Loader:
Lift Capacity to Full Height at the Pivot Pins - 2050lbs
Lift Capacity to Full Height at the Cutting edge - 1480lbs
Breakout Force at Pivot Pins - 5140lbs
Breakout Force at Cutting Edge - 3695lbs
Rollback force with bucket on the ground - 2266lbs
Maximum Height to Lift Pin - 107.5"
Maximum Lift Height w/ Bucket Level - 102"
Reach at Maximum Height - 21.38"
Maximum Dump Angle - 45 degrees
This loader was not involved in the torque box modification issue.
Hope this helps
/ DK45 data wanted
Michigan Iron-
Thanks for the data on the loader. I am a data guy and not having it was driving me nuts. Do you have any comments on it being the same as the Rhino?
I will be in touch, hopefully, about the thumb as I said in PM. Tractor has PTO pump for BH and according to dealer rear remote are standard. Do you think I can use the rears to run the thumb? Hope so! Thanks again.
Matt
/ DK45 data wanted #7
Many people use rear remotes to control a grapple. Controlling a thumb is a little different as you are not sitting in the driving position when using the BH and may not be able to reach the rear remote controller handle. You could rig a separate cheap valve near the BH controls and power it from the rear remotes or you could power it from one of the stabilizer circuits.
/ DK45 data wanted #8
Yes, our hydraulic thumb kits inlcude the extra valve to control the thumb. The thumb circuit would plug into a rear remote circuit. We have put the same thumb kits on the DK45S and DS4510.
2010 FORD RANGER SINGLE CAB PICKUP TRUCK (A59914)
2010 FORD RANGER...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
78in. Skid Steer Bucket (A65640)
78in. Skid Steer...
2013 XCMG PADFOOT COMPACTOR CV122PD (A65643)
2013 XCMG PADFOOT...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
