DK4210 Cab electrical.
/ DK4210 Cab electrical. #1
HDSS250
Kioti CK35
Recently I traded in my CK35 for a DK4210SE. I replaced the work lights with LED's. Next I started to install a radio. I had issues with the radio not holding any memory. My dome light in the cab was not working. The fuse diagram shows these 2 are on a 5A fuse. Opened the fuse box and indeed the 5A was blown. Replaced the fuse and then the tractor would not turn over. Took out the 5A fuse and the tractor started. Any ideas? Thanks John.
/ DK4210 Cab electrical. #3
How did you ground and grab power for your new stuff? Also is the tractor sitting where mice can get to it?
Not that I am aware of.
I used the wires on the original lights for the LED lights. For the radio I used the wiring harness and plug for the radio. Mice have not been an issue prior- no signs. It appears the original 5A fuse had been blown for some time.
/ DK4210 Cab electrical. #6
Wherever that 5 amp fuse connects up to is going to ground somewhere. You'll need to trace the circuit back to see where it's grounding. You might try disconnecting the dome light and see what happens.
Mini Universal Forks (A65640)
Mini Universal...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
Unverferth Ripper Stripper (A64126)
Unverferth Ripper...
2015 FREIGHTLINER CASCADIA T/A DAYCAB TRUCK TRACTOR (A59914)
2015 FREIGHTLINER...
(4) 10-16.5 Tires (A65640)
(4) 10-16.5 Tires...
2016 Jeep Compass SUV (A64557)
2016 Jeep Compass...
