DK40SE width with industrial tires
   / DK40SE width with industrial tires #1
canoetrpr
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
Island or anyone else who might not mind - could you you measure the width of your DK40SE tractor from tire to tire.
Trying to get an idea of whether one can get by with a 5ft bush hog (probably not) and a 5.5 ft snowblower (probably).
   / DK40SE width with industrial tires #2
I'll measure accurately this weekend if the weather holds....however I am pretty sure it is over 60 inches and under 65 inches. Here are some photos from the rear with a 75 inch flail mower. The left side is flush with the mower. I'll let you do the trig/math.;)
I would buy a 6ft cutter if I were buying new but if I already had a 5ft brush mower I think it would be fine.
   / DK40SE width with industrial tires #3
Is the 45 wider than the 40 frame wise or is the difference in the tires?
   / DK40SE width with industrial tires #4
Tires. I'm pretty sure the only difference is the tire size and that the frames and engine blocks are identical. I think the onlly difference with the DK35se is that the 3cylinider engine block is shorter so the tractor is shorter and also the DK35se tires are smaller.
   / DK40SE width with industrial tires #5
Ok, thanks. I was just curious based on your comment about buying a 6ft cutter. I bought a six ft. cutter and a 7ft. finisher. They both are great, however sometime I wish I had an extra foot on the finisher.:)
   / DK40SE width with industrial tires #6
IslandTractor said:
I'll measure accurately this weekend if the weather holds....however I am pretty sure it is over 60 inches and under 65 inches. .
I was wrong. It measures 68 inches from outside of R4 tire tread lugs. It would not fit through a 68 inch gate as the tires bulge out another couple inches on each side but the foot print is 68 inches wide.
Thanks a bunch.
UNUSED CFG INDUSTRIAL QK16R EXCAVATOR (A51247)
UNUSED CFG...
2020 COLOMBO TM LOT IDENTIFIER 201 (A53084)
2020 COLOMBO TM...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
