DK40SE hydraulic leak at valve body where steering column attaches
   / DK40SE hydraulic leak at valve body where steering column attaches #1
jbcompu
Has anyone else seen this problem. The steering column goes into a valve body and there is a seal where the column enters the valve body. Does
anyone know if the seal can be replaced or does it require a new valve body with seal installed ?
  • Kioti Tractor steering column seal.pdf
   / DK40SE hydraulic leak at valve body where steering column attaches #2
After seeing the price of a replacement I believe I would be figuring out how to replace that seal. :oops:
Unfortunately Kioti does not offer the parts or the breakdown on the valve. Same thing with my LK 2554. I was able to get parts from Kubota for mine.
I would start by taking it out so I could work on a bench. Then figure out how the seal is installed and come up with a technique to remove it. Then go to a bearing shop and have them get me a replacement. They had to put it in so there must be a way to get it out.
HEAVY DUTY TRACTOR BRUSH GUARD (A51247)
HEAVY DUTY TRACTOR...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53472)
2023 NEW HOLLAND...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2019 Ford F-450 Service Utility Truck, VIN # 1FDUF4HT9KDA04609 (A51572)
2019 Ford F-450...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
(2) 300 GALLON POLY TOTES (A51248)
(2) 300 GALLON...
