DK40SE hydraulic leak at valve body where steering column attaches
   / DK40SE hydraulic leak at valve body where steering column attaches #1
jbcompu
Has anyone else seen this problem. The steering column goes into a valve body and there is a seal where the column enters the valve body. Does
anyone know if the seal can be replaced or does it require a new valve body with seal installed ?
  • Kioti Tractor steering column seal.pdf
   / DK40SE hydraulic leak at valve body where steering column attaches #2
After seeing the price of a replacement I believe I would be figuring out how to replace that seal. :oops:
Unfortunately Kioti does not offer the parts or the breakdown on the valve. Same thing with my LK 2554. I was able to get parts from Kubota for mine.
I would start by taking it out so I could work on a bench. Then figure out how the seal is installed and come up with a technique to remove it. Then go to a bearing shop and have them get me a replacement. They had to put it in so there must be a way to get it out.
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
