Dk40SE HST front Axle grease zerk Question.
   / Dk40SE HST front Axle grease zerk Question. #1
CowwFace
Conifer, Colorado
Kioti DK45SE HST, 401FEL, RB40-96 pivoting Rear Blade
Hey List,
Does anyone know how much grease the zerk on the end of the Axles (see pics) of the DK40SE HST should take? I know I've greased these before .. but I've put in 15 pumps and I don't see any grease oozing from anywhere??
Tractor On,
   / Dk40SE HST front Axle grease zerk Question. #2
Anything with grease seals I only will do a max of 3 pumps with a standard 12 oz grease gun. I watch the seals closely and stop when they start to swell. I usually grease spring and fall. Do you have a seal leak? Do you have signs of grease on the axle in this area.l
   / Dk40SE HST front Axle grease zerk Question. #3
3 shots per fitting.
Thanks for the reply guys,
I don't see any signs of any leaking. I replaced the front dif gear oil at the 50hr scheduled maintaince (have about 160hrs on machine now) and the peep hole shows full there.
Lets just say, hypothetically of coarse, someone shot 15 pumps into each side .. would that cause any harm? more is better right?
Tractor on
Phill
   / Dk40SE HST front Axle grease zerk Question. #5
No, more is not better. More will break the seal sometimes or create a mess. 3 to 5 shots max per fitting. Use less MORE often.
   / Dk40SE HST front Axle grease zerk Question. #6
No, more is not better. More will break the seal sometimes or create a mess. 3 to 5 shots max per fitting. Use less MORE often.;)
   / Dk40SE HST front Axle grease zerk Question. #7
Looking at your pictures and the grease fittings & upper seal you have no issues of being over greased as seals have not weeped any out. No worries.
DevilDog
   / Dk40SE HST front Axle grease zerk Question. #8
From the attached links of parts diagrams, there are seals to keep water out which probably would also keep the grease in. Excess grease looks as though it would just go into the axle housing. Enough grease might eventually keep axle oil from reaching the bevel gears at the end or the grease would start to mix with the axle oil and maybe not flow to where it's needed. As mentioned, 3 pumps at scheduled maintenance should be fine.
OEM Parts
OEM Parts
The wisdom on this list is a wonderful thing!
Thanks for your responses. I bet my extra pumps did go into the axle housing .. have to be ok, because I aint going in there to get it out! Thanks for the diagrams of that seal VictorW!
I've added "user less grease MORE often" to my vernacular as well, Thanks Murphy.
3 strokes every 50 hours sounds good to me.
Tractor on,
Phill
   / Dk40SE HST front Axle grease zerk Question. #10
Tractor on
Phill
See red text above... That is a sight glass with a white ball and it should be full to where the ball is floating in the red circle in the center of the sight glass, NOT to where the sight glass is full. There needs to be room for expansion so the pressure doesn't blow out the seals when the fluid expands on hot days.
And check your maintenance schedule for how often to grease the zerks on the tractor- I don't recall it being 50 hour intervals.
WIGGINS 5K FORKLIFT (A52472)
WIGGINS 5K...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2019 Ram 2500 Pickup Truck, VIN # 3C6UR5DL0KG545677 (A51572)
2019 Ram 2500...
