DK40SE Fluid Capacities
   / DK40SE Fluid Capacities #1
Bender1
Boise, ID
Can someone help me out with capacities for my tractor? I have searched both here and Google and can't believe I can't find the info?
Particularly I want to change the motor oil tomorrow. I was planning on using DELO 400 15-40 but after reading a bunch of threads I think I will use the synthetic Rotella.
I assume the owners manual has all this listed but I haven't picked one up yet:rolleyes:
Thanks, Dan
   / DK40SE Fluid Capacities #2
Engine oil - 8L /8.4 qt.
Hydraulic fluid - HST - 42L - 11.1 gl. (shuttle/gear) - 13/7 gl.
front axle - 7.6L / 8 qt.
Excellent! Thank you! I got a million hits for fuel and hydraulic but not 1 for engine.
   / DK40SE Fluid Capacities #4
I used The Rotella T6 5w40 Synthetic, great results in this cold weather.
2 gallon jugs filled mine to the full mark with filter change after letting it drip and drizzle for a long time.
Cut yourself a piece of thin cardboard and make a trough to put under the oil filter, so it doesn't drain all over and make a mess:thumbsup:
   / DK40SE Fluid Capacities #6
Soot will build up in any oil (dino or synth) so you can't extend change intervals by using synthetic. Synthetics should keep the engine a little cleaner inside but the main advantage (of synthetics) is cold weather starting. All Mobile 1 is 100% synthetic but you need to read the label on the Rotella as there are several versions. Personally, I use full synthetic oil; it's not a great extra cost considering the value and useful life of a tractor.
Some large Diesel engines use special filters that can remove soot from the oil to extend change intervals. This is not cost-effective for small auto or tractor engines.
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52748)
Adams Load Out...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
2007 INTERNATIONAL PAYSTAR 5600I (A52472)
2007 INTERNATIONAL...
2006 CHEVROLET SILVERADO 1500HD (A52472)
2006 CHEVROLET...
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
