DK40 SHIFTING ISSUE
/ DK40 SHIFTING ISSUE #1
NUTFARMER 1
2003 KIOTI DK40 CR
Just a quick update on a past post from Nov. I took my DK40 back apart and checked everything I could think of or had equipment for. Release bearing forks are tight and no deflection when twisting between linkage arm and forks with a crescent wrench and channel locks. Flywheel runout is only .001. I still question the preassure plate I had sent out and had rebuilt since I had a similar dragging issue before and this is the only main component I reused. I think the culprit though is the clutch disc, it has .039 runout and that seems excessive. I tried putting a drill motor to the PTO drive shaft ( inside the main input shaft that is driven by the clutch ) and was able to shift the trans indicating that the issue does not appear to be dragging between the input shafts. It just acts like when a pilot bearing seizes, but this has no pilot bearing- that's where the PTO input is. If anyone has some other ideas before I put this back together let me know, other wise I have ordered a 6 puck heavy duty new disc and a new pressure plate. If this doesn't work I'm going to put it back together with Velcro next time.
/ DK40 SHIFTING ISSUE #2
I don't know about the .039 runout. I've never felt the need to make that particular measurement on a dry clutch disc. Then again, I don't recall a similar situation where the problem wasn't self evident. I would think the travel distance of the pressure plate surface when fully released(disengaged) would be enough that .040 wouldn't be a noticeable problem. I guess you will inspect the next replacement disc as well and let us know how it checks out?
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
2019 JOHN DEERE 333G SKID STEER (A64279)
2019 JOHN DEERE...
CATERPILLAR D5K2 LGP CRAWLER DOZER (A64279)
CATERPILLAR D5K2...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
