DK40 SHIFTING ISSUE
   / DK40 SHIFTING ISSUE #1
NUTFARMER 1
2003 KIOTI DK40 CR
Just a quick update on a past post from Nov. I took my DK40 back apart and checked everything I could think of or had equipment for. Release bearing forks are tight and no deflection when twisting between linkage arm and forks with a crescent wrench and channel locks. Flywheel runout is only .001. I still question the preassure plate I had sent out and had rebuilt since I had a similar dragging issue before and this is the only main component I reused. I think the culprit though is the clutch disc, it has .039 runout and that seems excessive. I tried putting a drill motor to the PTO drive shaft ( inside the main input shaft that is driven by the clutch ) and was able to shift the trans indicating that the issue does not appear to be dragging between the input shafts. It just acts like when a pilot bearing seizes, but this has no pilot bearing- that's where the PTO input is. If anyone has some other ideas before I put this back together let me know, other wise I have ordered a 6 puck heavy duty new disc and a new pressure plate. If this doesn't work I'm going to put it back together with Velcro next time.
   / DK40 SHIFTING ISSUE #2
I don't know about the .039 runout. I've never felt the need to make that particular measurement on a dry clutch disc. Then again, I don't recall a similar situation where the problem wasn't self evident. I would think the travel distance of the pressure plate surface when fully released(disengaged) would be enough that .040 wouldn't be a noticeable problem. I guess you will inspect the next replacement disc as well and let us know how it checks out?
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2015 CATERPILLAR 745C 6X6 OFF ROAD DUMP TRUCK (A51242)
2015 CATERPILLAR...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
2016 MACK TITAN TD713 (A51219)
2016 MACK TITAN...
2018 INTERNATIONAL LT625 TANDEM AXLE DAY CAB (A51219)
2018 INTERNATIONAL...
2012 Captiva Sport (A50324)
2012 Captiva Sport...
