DK40 grill guard
/ DK40 grill guard #1
alancamby
Indiana
Kubota L2550 Kioti DK40
I have a 2013 DK40 that has already suffered a few blows to the lower grill in the woods. Don't really like the idea of adding expanded metal to the factory GG due to lack of coverage of the factory GG down low. So decided to build a GG with better coverage.
I could try and describe it but will just post some photos instead.
/ DK40 grill guard #2
Dang, that is a serious grill guard.:thumbsup:
/ DK40 grill guard #3
I like the fact that the lights can shine through the guard (vs on it).
/ DK40 grill guard
Thanks guys.
Here is a picture before paint with the lights on.
/ DK40 grill guard #5
THAT is some serious protection - very nice, clean, functional. A lot of thought and good craftsmanship.
/ DK40 grill guard #6
Great looking set up.
/ DK40 grill guard #7
Man thats hefty, looks like something the Cops use.
/ DK40 grill guard #8
That is very well done! How did you bend the bottom bracket, or was that metal already at a 90 degree angle?
/ DK40 grill guard #9
I believe that was a piece of U channel iron he cut the other "ear" of the U off, and shaped it the way he wanted it.
/ DK40 grill guard
Thanks again for the comments.
Yes the bottom bracket started out as a C-channel.
This C-channel is a little odd compared to what is available in the USA.
It is a piece of Metric Channel that was used as a crate for large Japanese CNC machines.
It measures 3"x6" with a center of the web thickness of .350"
The metal was just slightly to small for the Kioti GG/weight rack bolt pattern. I had to mill reliefs where the bolts meet the contours of the metal. And yes the bottom angle was milled off.
The rest of the grocery list.
all square tube is 3/16" and all rectangle is 1/8"
-2x2" square
-1.5x1.5" square
-1x2" rectangle (technically 11gauge .120")
-1.5"x1/2"x1/8" c-channel for grill
-3x3"x3/8" angle
-The bottom inner bolt mounts on the GG are modified 2"x2"x1/4" square with one of the sided cut out of the square.
-5/16-18x3/4" SS button screws with HD SS washers, all 18-8 grade.
-1/2"-13x1" grade 8 HHCS LE stamped (Lake Erie made in Indiana)
-M14 grade 10.9 flat washers.
-factory M14x1.5x40mm grade 9 HHCS
All welded with .035" MIG wire. Millermatic 212.
All bolts Blue locktited.
/ DK40 grill guard
The Grill slats are spaced 10mm apart. To make this easy. I used a bunch of M10 x 12" long keystock to use as spacers during fabrication.
The reason I don't like expanded metal. It is to easy to bend and hard to bend back once it bends/stretches. Nearly impossible to paint properly. Hard to eliminate sharp edges.
Biggest issue is the paint problem. If you go to a trailer lot, all the rear drop gates on new trailers have rust bleeding out of where the expanded metal meets the tube. How can you get paint between the expanded and the square tube. Even the powdercoated trailers suffer from this.
I bolted the slats so that they would be replaceable and paintable on all sides. If the slats were welded. They would need to be welded all the way around on all sides or rust would creep out. That would be a lot of welding.
/ DK40 grill guard
I changed my oil and air filter today. Decided to install a inner air filter along with the outer.
Anyhow I snapped a photo with the front grill off. It wasn't necessary to remove the front but I had both sides off for the maintenance anyway. I am at 76 hours.
Here he is out in the snow a few days ago.
/ DK40 grill guard #14
While you have that open (or next time) you might thing about putting your favorite battery grease on the battery terminals to keep the fumes from starting corrosion there. I use NO-OX-ID. made by Sanchem. I have used it for years with good success. While I am at it I put some on the screw threads of the battery retainer bolts too. How many times have you seen bolts near a battery that are always rusty and or corroded to the point they just break off? I believe in coating them to protect them.. YMMV..but that is what I do.
2022 EZ-GO ELITE...
(4) Wheels and Tires for 4-Wheeler (A65579)
(4) Wheels and...
ATS ATS-PC90 Heavy Duty Plate Compactor (A62679)
ATS ATS-PC90 Heavy...
John Deere 7000 4R Planter (A66408)
John Deere 7000 4R...
100 Gallon Plastic Tank (A65640)
100 Gallon Plastic...
Skid Steer Trailer Mover (A65640)
Skid Steer Trailer...
