DK40 Box Blade size? 72"? 78"? 84"?
   / DK40 Box Blade size? 72"? 78"? 84"? #1
IXLR8
Eastern Shore- Virginia
Kioti DK-40SE
I have a new DK40, loaded rear tires and Fel, I have some chores that I think a box blade would be good for. We have a 1/4 mile long dirt road that the neighbor hires out to have maintained. Only issue is the guy who does the work always levels the road and doesn't put any crown on it, which of course leads to pot holes and wash out. Road is established, 20 years old, and just needs to have a crown put on it and the pot holes broken up and filled in. I also have some area's of lawn that I want to level out, nothing larger than 40' x 30'. R4 tires set at their widest position, measure about 71" outside to outside. As there is a 1' drop off at the edge of the road, I was thinking of getting the 84" BB to keep the tires away from the edge. I don't have much cleaning up to do the road so I won't be taking big bites, just a little shaving here and there. I was looking at the Everything Attachments 84" utility tractor BB. Any thoughts or input if it will be too big or if the DK40 can handle it. I do have TnT, just haven't installed them yet.
Thanks
   / DK40 Box Blade size? 72"? 78"? 84"? #2
I would use a 78" or so Land Plane with a TnT set up.
   / DK40 Box Blade size? 72"? 78"? 84"? #3
I second Murphs post. Go to big and it will be hard to put a crown on road. Also it may be hard to level your yard. In the end I think you have a great tractor and it will pull up to 84 inch with no problem.
Scott
   / DK40 Box Blade size? 72"? 78"? 84"? #4
I would go with atleast a 78'' but a 84'' would be better.
As part of their rental program my local Kubota dealer has a Land Plane, with scarifiers. If it is wide enough, and available, I will have to try it out. They don't have a box blade for rent, but they do have the Land Plane... but every time I have contacted them about it... it is out so I have not even seen it yet. Seems it is typically rented out 4-6 weeks out, which is why I was looking at buying so I didn't have to deal with the hassles of scheduling renting.
   / DK40 Box Blade size? 72"? 78"? 84"? #6
That's what I have and it works great. How wide is your drive?
never measured it... it is a single car wide dirt road, it is within a 20' wide ROW, I am guessing 15'. I won't be home again until Wed afternoon to verify.
   / DK40 Box Blade size? 72"? 78"? 84"? #9
For a land plane or medium duty box blade, I'd probably go with 78" or 84" also. But I just bought a 72" Gannon box blade with hydraulic scarifiers and it is a real heavy duty beast. I'm not sure I'd want one any bigger. They had an 84" one, but it only had a Category II hitch, so I didn't have to make a decision.
   / DK40 Box Blade size? 72"? 78"? 84"? #10
A box blade like a Gannon is way heavier and holds more material so it is going to pull harder than a light weight wider box blade.
INOP/NON-RUNNING Chevrolet Rollback (A51572)
INOP/NON-RUNNING...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
2009 Lee-Boy 8510HD Conveyer Feed paver (A53472)
2009 Lee-Boy...
2006 CHEVROLET SILVERADO 1500HD (A52472)
2006 CHEVROLET...
