dk35 se not starting
   / dk35 se not starting #1
Jimbrady
Tonawanda,ny
Kioti dk35
ran the tractor when it was snowing very hard, parked it for the nite,went out the next day turned the key on everything on the dash lite up like usual, but it didn't crank over all the lights work, once in awhile I would have to giggle the shifter to get it to start. any suggestions?
   / dk35 se not starting #2
Sure sounds like the safety cutout switch on the shifter/transmission. If you have the shop manual, or parts manual, you might be able to find a spot where you can bypass the switch to get you through until you can get it fixed properly.
I was told its not just a switch
   / dk35 se not starting #4
Who told you that? What did 'they' say it was? Why ask here if you've already been told what it is?:confused2:
I read something on here that is was a potentiometer that has 5 volts going through the shifter switch, and you cant bypass it like a normal switch
   / dk35 se not starting #7
And he is correct. Check battery voltage and clean and check your grounds.
I don't know where the switch is located, its to cold (-6 out) to go out there and start working on it! I'm hoping this weekend it gets up to the mid 20's and I can go out to look at it.
I did check the voltage and that was fine, I hope to check the connections this weekend.
   / dk35 se not starting #10
The "range selector" lever is read by a potentiometer, (similar to a switch, but it reads a scale from 0 to 5 Volts, rather than just on/off).
If you move the range selector to the forward neutral position, does it start? Sometimes the pot may have a dead spot, but either neutral position should allow it to start, IF it's working correctly.
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
DEMAG ELECTRIC CHAIN HOIST W/ RAIL & TRUCK (A52708)
DEMAG ELECTRIC...
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
CASE INTERNATIONAL 183 4R DANISH TINE CULTIVATOR (A52708)
CASE INTERNATIONAL...
