DK 55C
   / DK 55C #1
gmol
Vermont
Kioti DK 55-New Holland EC-35
I have owned LK 2554 , LK 3054 and presently own a DK35 . I am thinking about trading up again for a DK 55C . I do some grading but mostly loader work , logging , plowing in the winter, and using the tractor as a wheel barrow in conjunction with a New Holland EC 35 mini excavator. The question is do you guys that own DK 50-55 think this tractor will work well in the woods as a skidder with a winch. The DK35 is a great size to fit every where with minimal damage but skidding larger diameter logs one at time is not real cost affective . Any thoughts are always appreciated. G
   / DK 55C #2
I don't own a 50 or 55, but I do have a DK 45. I've pulled some pretty large trees a couple at a time, but it was pretty much in open fields. My biggest concern would be if you go with a 55C (that's Cab, right?)-will the cab get damaged skidding logs in the woods/forest? I've seen lots of skidders with cabs, but they also have beefy steel guards and expanded metal around them (is this your plan with the Kioti as well?).
I don't know if the DK 55 has a front diff lock like the 65 does. I would think that would be very helpful for skidding large loads in tight quarters.
Good Luck
Take it Easy
Tim Gray
2014 Nissan Maxima Sedan (A50324)
2014 Nissan Maxima...
Set of AG R4 Wheels and Tires (A52128)
Set of AG R4...
2018 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
