DK 55 loader speed
   / DK 55 loader speed #1
gmol
Vermont
Kioti DK 55-New Holland EC-35
O.K. sorry but this is the last try. I had the tracotr at dealers all winter to get things worked out. Loader specs out with the tracotr hydraulics and pressure. BUT it is so slow !!! Any one have any pearls of wisdom besides selling this rig. It has a Woods 1020 loader . It is trong and the curl angle and power are good but wow baby is it slow to curl and dump ! Please help !!
   / DK 55 loader speed #2
I know you wont want to hear this but.....
If you increase all of your hydraulic line to 1/2 inch you will get the speed.
   / DK 55 loader speed #3
Or maybe just replace the curl and dump lines with 1/2 inch???
   / DK 55 loader speed #4
Are the cylinders on the Woods loaders larger diameter?
   / DK 55 loader speed #5
It could be a number of thigs causing the problem. The main thing is likely geometry. The original loader was designed with very quick dump and curl as you may remember. To achieve this, they gave up some roll back power. So, when you changed to the woods loader, it has different geometry as well as it may have bigger cylinders which require more oil further reducing cycle time. Pump capacity it cannot be changed. Max output is max output.
   / DK 55 loader speed #6
First, something cheap. Remove the quick attach couplers and "hard plumb" the lines. This should help, by removing the small restriction of the couplers.
"I always check the simple things first"
Slingblade
   / DK 55 loader speed #7
Maybe try some ritalin for the operator each time before using the loader? /forums/images/graemlins/grin.gif
   / DK 55 loader speed #8
There are speed specs on the loader as well. If it's under warranty and not meeting the speed, then place the burden on the dealer to correct it, whatever the cause.
   / DK 55 loader speed #9
Don't know what to say. I guess the obvious is that the loader works faster at higher RPM due to the higher flow of the fluid.
If you're operating at low RPM, any loader is going to be pretty slow. Other than that, Rick Wallaces suggestion to change out the hoses is about the only real fix I know of, but I'm no hydraulic expert, not by any means.
John
   / DK 55 loader speed #10
Gmol, you could also try this for a quick fix.
Brown 417 7ft Rotary Cutter (A50490)
Brown 417 7ft...
2009 Chrysler Sebring (A50324)
2009 Chrysler...
2014 Chrysler Town and Country Van (A50324)
2014 Chrysler Town...
2018 John Deere R4038 Self Propelled Sprayer (A50657)
2018 John Deere...
2017 BOMAG BW145D SMOOTH DRUM ROLLER (A51242)
2017 BOMAG BW145D...
2015 Volvo VNL300 Semi (A50514)
2015 Volvo VNL300...
