DK 55, Hood latch problem
/ DK 55, Hood latch problem #1
emj
Hi all,
I have a 2011 DK55, the hood release won't work at all.
Any ideas to get the hood open?
Thanks,
Ed
/ DK 55, Hood latch problem #2
First try "unloading" the force on the latch (by pushing the hood) and try the release again. If that doesn't work you will probably need to drill or find a hole that will allow you to poke a wire in there and trip the latch. Also unload the latch forces when you try this. You probably need to study drawings or photos of the latch to know where to pull. This will likely be frustrating.
It goes without saying that, once it is open, you need to fix the cable before closing it again.
What flavor DK55 do you have (DK55SE?)? Hopefully someone with the same model can take photos and maybe measurements that will assist you.
/ DK 55, Hood latch problem #3
We have a 04 CK 30 and every since new it takes a light pull on the knob and a slap on the hood to open .
/ DK 55, Hood latch problem #4
Same here for my ck27. I have to push down on the hood just enough to unload the latch. Once I do that it pops right open.
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
John Deere Planter (A62613)
John Deere Planter...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
John Deere Zero Turn Lawnmower (A65579)
John Deere Zero...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
Landhonor Plasma Cutter (A66408)
Landhonor Plasma...
