Tires DK-50 tire warning
   / DK-50 tire warning #1
treesawer
I figured it would happen sooner or later,a limb rose up inside my back tire rim & broke off the threaded brass stem(too soft a metal for this purpose). I lost a few gal. of fluid but did catch it in time to roll the stem on top.
If this happens to you a new part is about $15 & a few days to find one maybe. I fixed mine a different way without taking the tire off. I had enough stem sticking out to rethread the hollow tube & threaded a special stem back in place. My warning to those who might drive thru brush or over large limbs on the ground,weld a steel cup over these fragile stems on both rear rims(my fronts have this feature)
treesawer
   / DK-50 tire warning #2
I hope you didn't load the back tires without tubes these tractors come tubeless from the factory
   / DK-50 tire warning #3
<font color="red"> </font>" I hope you didn't load the back tires without tubes these tractors come tubeless from the factory "
Why?I loaded my tubeless tires with W/W fluid.If I pick-up a nail I can still plug it.Are you concerned about rust?.....Mike
   / DK-50 tire warning #4
If they are loaded with calcium.Yes I would worry about rust people used to load lawn mower tires without tube only lasted about a year
Ok, I welded a nice ring around each stem so I am safer I think. I see Tractor Supply carries the top part of the stem
for under $4. /forums/images/graemlins/smile.gif
(8) TRACTOR WEIGHTS (A51244)
(8) TRACTOR...
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2016 John Deere 6155M (A50120)
2016 John Deere...
AGT Industrial Planter Attachment (A47384)
AGT Industrial...
2020 BROCE BROOM RCT350 SWEEPER (A51242)
2020 BROCE BROOM...
