DK 45 SE quick attach lever arm is loose
   / DK 45 SE quick attach lever arm is loose #1
StuartDK45SE
Angleton, Texas
Kioti DK45SE
Hello all. I have a 2012 DK 45 with the KL401 FEL. The arm to disengage various front end attachments works fine, but there is one really annoying thing. When I have the arm in the disengaged position, it will not stay there on his own 95% of the time. So the scenario goes like this. I want to take my bucket of let's say. I get to where I want to set it down, pull the lever to disengage the pins at the bottom, EASE the FEL down and 9 times out of 10, the arm will flop downward and the pins will engage in the holes again. So, its back off the tractor to set the arm again. I've tried bungee cords to hold the arm in the disengaged position and that woks, but that is a pain also.
The arm pivots in a dog eared type connection, so there is not tightening that bolt up to increase friction. Anyone have the same issue and how did you fix it? Minor I know, but oh so frustrating.
   / DK 45 SE quick attach lever arm is loose #2
   / DK 45 SE quick attach lever arm is loose #3
Are you sure you cannot tighten the bolt a little. I have a different set up, but mine loosen about once a year. Tighten them up a little.
   / DK 45 SE quick attach lever arm is loose #4
Mine does the same. I use a bungee cord.
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
2021 KOMATSU D39PX-24 CRAWLER DOZER (A51246)
2021 KOMATSU...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
