DK 45 Losing Power under load
   / DK 45 Losing Power under load #1
wxtrendsguy
Breinigsville
Kioti
2014 DK45 with a vineyard CIMA airblast sprayer on the 3 pt. Running at 2500 RPM which is the PTO at 540. Flat ground not seeing any issue, however going uphill in low gear at 2-3 mph and the tractor is fine but after about 100 feet going up a 10% slope the RPMs drop and the tractor slows and sounds like its really lugging. Stop forward motion and the RPM comes back up but as soon as I try to move forward the RPMs drop. Turn off the PTO and the RPMs come right back to full power and I can drive up the hill with no issues.
I am guessing its a hydraulic issue since this tractor model is a hydrostatic transmission so the hydraulic system is heavily used for everything. I don't think its a fuel issue but it could be the fuel filter...
   / DK 45 Losing Power under load #3
I am guessing its a hydraulic issue since this tractor model is a hydrostatic transmission so the hydraulic system is heavily used for everything. I don't think its a fuel issue.
Is there any wheel slippage? Thats a pretty decent slope for one wheel to pull
How long since you changed the fuel filter? If you haven’t done that recently that’s the first and easiest thing to do….
Its been some time but I can change that easily enough and was planning to do that before a full blown messy hydraulic dump and filter change.
There is no wheel slippage. When the sprayer is loaded there is plenty of weight on the back end to keep from spinning wheels. Its the engine RPM that drop dramatically, if I was spinning a wheel I would not expect to see the engine lug like it does...could be fuel filter or hydraulics are still my first guess.
   / DK 45 Losing Power under load #6
How long have you had this tractor and that sprayer hooked together?
Looking at those sprayers the smallest requires 25 PTO just for the sprayer, then add in the Hp required to move your tractor up that hill in addition to powering the sprayer.
Trying to maintain that 2-3 mph to keep the same sprayer coverage may require more tractor Hp then you have.
It may be a fuel problem or even an air flow restriction.
I doubt that it is a hydraulic problem, your tractor has a hydrostatic transmission which consists of a hydraulic pump and motor in a combined unit for ground work. Your PTO is strictly mechanical in power transmission, your hydrostatic transmission is separate from the PTO and the other tractor hydraulics.
The tractors hydraulic pump(s) supply hydraulics for cylinders and such and your 2 point hitch and power steering.
It is also the charge pump supply for your transmission, in other words it makes up fluid for what "leaks" from the pump/motor it does not power the tractor.
Interesting. I have been running this combo for nearly 10 years with no issues. One time late last summer I had an issue where the PTO would not engage the sprayer but no power loss. Added hydraulic fluid and the PTO worked fine and has been fine all year up till now. (I start spraying in May and every 10-14 days till September and each spray session is often 2-3 hrs of operating time.) So its a workout but the Kioti has not seemed to have any trouble till now. Going to swap out the fuel filter and air filter tonight to see it that is an issue before diving into any further causes. Thanks for the suggestion and info
   / DK 45 Losing Power under load #8
Hadn't seen you say, have you checked the hyd fluid level? Is it discolored?
Yes it was about a quart low when I checked it cold last night. Cannot seem to get an answer from anyone on the proper timing of when to measure using the dip stick. Fluid is nearly clear.
Turns out your information is only partially correct. I talked to a dealer late this afternoon and while it is true that the PTO is driven by the engine the PTO is engaged by a hydraulically driven clutch which uses hydraulic pressure to clamp the plates together in the the PTO clutch. So low or dirty hydraulic fluid can cause the clutch to slip and the PTO to lose power or disengage slowly. Still does not yet explain the loss of power and near stalling of the engine...so could be 2 problems...low fuid/clogged filter and fuel or air filter issue.
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
UNUSED RAYTREE RMLL60-60" POWER RAKE LAND LEVELER (A51248)
UNUSED RAYTREE...
MURRAY 22" GAS PUSH MOWER (A51248)
MURRAY 22" GAS...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
E-Z-Go Freedom TXT Electric Golf Cart (A51694)
E-Z-Go Freedom TXT...
2023 John Deere 8R 410 Tractor (A53342)
2023 John Deere 8R...
