DK 45 Hits the 1000 mark
   / DK 45 Hits the 1000 mark #1
Oleozz
Pa.
International 1066 with Year Round Cab, Kioti DK 45S with Cab, 451 Loader
Bought it from Wallace in April of 2006, good deal, very good dealer. Only major problem was the injector pump going bad at around 900 hrs. Have used it for planting (pulls a 4 row no-till JD 7200), running a grain auger, spraying, mowing, disking, plowing (snow and dirt), lots of front end loader work with stone rake, forks, bucket, and grapple. All in all a decent machine.
   / DK 45 Hits the 1000 mark #2
Tractor looks to be in great shape considering all the work its done. I have never seen a hydraulic thumb, ( or should I say hand ), on a loader bucket. Im guessing it's welded or bolted to the OEM bucket. I like the concept and am very interested in it. Where did you purchase and are you happy with it. Pros and cons.
   / DK 45 Hits the 1000 mark #3
I heard nothing but good about Wallace. Wish they were still dealing in Kiotis.
Amvcane--The grapple cam from a welder in the Midwest, Iowa I believe. had it shipped here by freight.
The two front points weren't long enough so I had a local Amish welder extend the points and it now works much better. Total cost eight yrs ago for cylinder and grapple was around $500. If you are really interested I will try to find the shop's name.
Chuck 172----Wallace was nothing but helpful to me, would always take time to answer questions. Kioti left a good one slip away.
   / DK 45 Hits the 1000 mark #5
Thanks Oleozz, since I saw this thread I did some internet surfing and found a couple of companies with loader thumbs and even more By Net threads discussing the attachment. I don't really have a lot of use for the root part of a grapple as I mostly use the loader, but it would be nice to clamp down on something when needed without having to change attachments.
   / DK 45 Hits the 1000 mark #6
You managed to avoid the weak shift fork issue? My 2006 DK45SC now has 1052 hrs on the clock and is going strong. Most of the problems I've experienced, with the exception of the shift fork, have resulted from hard (some might say abusive) use...especially working in the woods. I hope we're good to go for another thousand (or two!) hours!
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
Miller Wildcat 350-D Welder (A51691)
Miller Wildcat...
2019 FREIGHTLINER CASCADIA SLEEPER TRUCK (A52577)
2019 FREIGHTLINER...
LMC LOT NUMBER 254 (A53084)
LMC LOT NUMBER 254...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
New Wolverine Push Blade (A53002)
New Wolverine Push...
