Dk 45 fuel tank removal, i need help.
   / Dk 45 fuel tank removal, i need help. #1
hogsndogs
north port fl
Kioti dk45
I've got the fuel tank loose in its compartment, but I can't get it out due to the steel tab that bolts to the top of the fuel tank frame. I've taken the console to floor bolts loose thinking that I could lean the console back far enough bit it won't lean the back. How do I get the tank out?
It helps a little, thanks.
Ok, got it out. It is a metal tank, and it is a used tractor. It must have sat for a while and built water up in the tank. After I cleaned it off, there ended up being 5 pencil lead sized holes under the paint. ( it had been leaking pretty bad, the paint had been bubbled up by pinholes in the tank and when I hit it with the pressure washer it uncovered all the holes.) Working on patching it up.
   / Dk 45 fuel tank removal, i need help. #6
Good work. Kiotis now have a plastic tank to avoid that problem.
If it is convenient and you have time, perhaps you can post a few photos for future reference.
I'll definitely put up some pics when I get back home.
   / Dk 45 fuel tank removal, i need help. #8
Patching it up? You are glutton for punishment, for every hole you can see, there are 3 or 4 thin spots getting ready to break through. I have never had luck with patches, it seems like I am right back taking the part out again in a few weeks/months/years (pick one) and then I have to buy a new one anyway.
I know but I can't afford a new tank right now. The prices I've found are in the 500 range. However I had to cut almost all of the bottom of the tank out and replace it with new metal. I know its not a permanent fix, but if it will get me through till summer, can live with it.
2025 New/Unused Wolverine Concrete Breaker (A51573)
2025 New/Unused...
GODWIN CD150 DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150 DRI...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
16ft 3in Box Blade (A51573)
16ft 3in Box Blade...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A53472)
2021 John Deere...
