DK 35 oil filter
/ DK 35 oil filter #11
I forgot to mention the valves also prevent leakdown so oil pressure is more consistant than it would be if it were allowed to leak down between uses. Thanks for bringing that up.:)
Scag, as mentioned is a pro level zero turn mower- made in USA. Very expensive- but they give excellent results and longevity/retain high resale value. I believe I paid $8000.00 for a 2 year old Scag Wildcat mower with a 60" deck and full bagger system, with only 200 hours on it - which for commercial use is NOTHING in terms of hours. New it cost over $11K
CHAINSAWS: I too have been having some issues with saws and lawnmowers and my 200HP Mercury Optimax Saltwater outboard.
A long time ago I was a pro tree surgeon, but a lot has changed in terms of saws and gas, not necessarily for the better.
I find that from what the guys who service saws, and sometimes my saws have to say is this: Ethanol wreaks havoc and makes everyone crazy. Stihl and Echo have branded their own oils, which for premixs contain ethanol treatment built in. BUT some saws with lots of hours on them and even new ones can end up with problems with the jets and needles and sometimes no matter what one does they just end up bolting on a new carb to solve many gas related issues. I've seem the 5 gallon buckets full of tossed carbs and its frightening as an owner of many carbed engines.
So there is no easy solution but these tips may help.
Run the highest octane fuel you can in your saws/ mowers/weed eaters etc. Higher octane allows for higher octane as the ethanol starts to degrade and phase seperate into WATER and other incombustibles. Use up ANY and all left over fuel in your car/truck so it gets used up instead of sitting in a can or tank where all the bad stuff goes to the bottom- right where the pickup is.
And continue doing what you're doing, running the saws out of fuel in their onboard tank if you're going to store the saw for some time- weeks or longer.
BTW, what's an electric chainsaw?!:laughing:
/ DK 35 oil filter #12
Coyote, Now you have me laughing too! I bought one of those "motor" driven 14" Craftsman saws at a yard sale for $2. Up at the "cabin" in Pa we have 35 acres of trees and rocks. We burn wood to heat the place. The Kioti 45 even gets a workout there and we usually drag the trees close to the cabin where we stack the wood after it is split. Trust me on this, that little 14" electric saw gets a workout and there is no pull to start. Since ethanol it isn't "pull to start" it's pull, pull, pull and don't start.
I use up the gas mix and gas that has been around for any length of time in the 20 hp lawn tractor/mower because we have "NFL" grade grass here (Delaware) which in the summer grows as fast as a politician grabbing at your wallet.
/ DK 35 oil filter #13
I have always been pleased with NAPA Gold Filters... and they are everywhere!
DK35 oil filter #1324 and fuel #3507
Just my 2cent's
1605 (A57192)
1605 (A57192)
STORAGE FEES (A59906)
2023 JOHN DEERE XUV 590M S4 UTV (A59823)
2023 JOHN DEERE...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2020 Bobcat E35 (A60462)
2020 Bobcat E35...
