Oil & Fuel DK 35 LOADING UP WITH FUEL
   / DK 35 LOADING UP WITH FUEL #1
hzsmith
LAKE OF THE OZARKS , GRAVOIS MILLS, MO.
DK-35
I HAVE A DK 35 WITH 4015 HOURS THAT WILL RUNN FROM 3 TO 15 MINUTES AND STARTS SMOKING AND LOADS UP WITH FUEL AND DIES. HAVE TO PULL START TO START.
HAS ANYONE HAD A SIMILAR PROBLEM? WOULD WELCOME ANY SUGGESTIONS. STARTS FINE COLD.
   / DK 35 LOADING UP WITH FUEL #2
does it die suddenly,as if you turned the key off...
or does it sort of wind down and slowly fizzel out?
First place I'd start is the fuel filter, fuel tank, lines... make sure someone has not "helped you out" by putting water in the tank..
   / DK 35 LOADING UP WITH FUEL #3
Did I read those hours correctly?? 4015?? I'd start off checking what Virgil mentioned, and then let us know what you find out. Looks like you aren't too from me down here in Kansas.
   / DK 35 LOADING UP WITH FUEL #4
If it was loading up with fuel enough to shut the motor down you would have extreamly heavy black smoke.
I agree with the others, most likely bad fuel, plugged filter or fuel line .
Wouldn't hurt to make sure the fuel tank vent is clear also.
2016 Ford Escape SE 4WD SUV (A50324)
2016 Ford Escape...
2019 GEHL RT105 SKID STEER (A51242)
2019 GEHL RT105...
2011 CATERPILLAR M318D MOBILE EXCAVATOR (A51242)
2011 CATERPILLAR...
2016 CATERPILLAR 962M LOADER (A51242)
2016 CATERPILLAR...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
