DK 35 Hyd Hose Burst - Supply to FEL Control Valve.
   / DK 35 Hyd Hose Burst - Supply to FEL Control Valve. #11
Something blew your hose, any idea. Perhaps a QD popped off.
That valve is still a valve for aux attachments, and has to be connected correctly for the flow to continue on.
Did you say your remotes fed your BH, if so, you should have 3pt. You have to bungee your lever, correct?
Does your remote valve have PB?
However your BH return should go to the tank because of back pressure from the 3pt.
However it is what it is, and if it works, then fine.
Thank You, again, J_J, much appreciate your assistance.
The supply hose chaffed at the bend from horizontal to the vertical, up towards the joystick for the FEL lever. The three hoses were "bundled" together, tucked in behind the FEL frame post and fwd of the right hand floor board. It is a 2006 model with 1200hrs so may be considered fair wear and tear considering it has spent the last 7 years or so working hard/roughly in my wood lot, maple bush.
My remote lever has detents so will stay in place if moved to full travel, else it will spring back to normal. I am not sure I understand what Power Beyond means or how it functions.
Ok, so I finally took the time to find previous threads & read up on Power Beyond. It seems like a pretty straight forward concept. Once again, I learned me a thing or two from this forum. Thanks.
22ft. T/A Utility Trailer (A56858)
22ft. T/A Utility...
Non- Running Asphalt Roller (A57454)
Non- Running...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
2014 Hyundai Veloster Hatchback (A56859)
2014 Hyundai...
2025 GPS GT612 S/A 12ft Utility Trailer (A56859)
2025 GPS GT612 S/A...
White 6138 Planter (A59814)
White 6138 Planter...
