DK 35 hi\low shifter stiff
   / DK 35 hi\low shifter stiff #1
mattman
ElDorado,AR
Kioti DK 35
I bought a used DK 35 with 165 hours on it. Tractor looks about like new. The only thing I have to question is how stiff should the high to low range shifter be?? Mine is very stiff. I am hopeing that it will get better with some more use. How about it does anyone else feel that their shifter is stiff??
   / DK 35 hi\low shifter stiff #2
I had that issue on my ck20 a while back, i had it parked outside most of the time and the weather, dirt and dust got to it. now i just spray the linkage points with some wd-40 every couple of months....
   / DK 35 hi\low shifter stiff #3
I have almost 800 hours on my DK35 and the selector is still stiff. Just keep it lubricated and it will be fine.
   / DK 35 hi\low shifter stiff #4
I only have 48 hours on mine, but it's stiff as well, if you mean going out or into a gear. But, I find that it is really due to the area I park it in. It's hard to shift when I am parked on an incline, otherwise it shifts real smooth. Maybe it's a matter of pressure on it form the weight of the tractor? Between gears it's really smooth.
Not sure if I am on the same page as you.
I am talking about the high, low shifter not the four speed gear shifter. I have not used the high to low shifter much because fourth gear low range is slow so I run in first gear high range for what I have been doing. I will look some more at the linkage but I did not see anything wrong with it. Will get some more seat time this weekend and see if it gets easier to shift after some use.
20ft Shipping Container (A57453)
20ft Shipping...
INTERNATIONAL S/A GRAIN TRUCK (A52708)
INTERNATIONAL S/A...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
HUM V (A58214)
HUM V (A58214)
14179 (A55788)
14179 (A55788)
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58018)
2018 FREIGHTLINER...
