DK 35 Block Heater
/ DK 35 Block Heater #11
I believe the hose dia. is 1 1/2" or 1 3/4" cannot remember off the top of my head. I have installed a heater into the engine block which I think works a lot better on all the tractors even the LK3054.
Dean Moore
/ DK 35 Block Heater #12
Do you mean the type of heater that goes into one of the engine block's freeze plugs? Don't you need to take the engine apart to put one of those in?
Spiny
/ DK 35 Block Heater #14
Block heaters are really not all that hard to install. You don't have to take most engines out to put in a block heater. The heater itself replaces a freeze plug (plug that closes off water passages around the block that are designed to pop out instead of cracking the engine in extreme cold temperature where the coolant expands due to freezing.) This is to answer the question of needing to remove the engine to put in a block heater. The freeze plugs look similar to upside down bottle caps minus the hand tearing edges. The actual block heaters I have installed either had an exact fit metal plug (softer metal) you basically tap it into place or they had a rubber piece that fills the hole with some kind of expansion plug. I have not had to remove a engine to put these in. I personally don't like radiator hose ones as they can cause wear to the hose itself by adding extra weight and movement to a spot that wasn't designed for it. I personally live in NW Oregon and we don't see the bone chilling temperature some of you others see. I would call a local automotive repair shop and ask them what they prefer to use for automotive applications as it will hold the same on the tractor end for a block heater. Most auto part stores probably carry a model that will work in the different tractor engines you just need to know the freeze plug size or radiator hose size.
/ DK 35 Block Heater #15
I have purchased two tractors from Little's and would highly reccomend them. The purchase, delivery and service after the fact was great. /forums/images/graemlins/smile.gif
Caterpillar 20'' Backhoe Bucket (A60463)
Caterpillar 20''...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2021 CATERPILLAR 262D3 SKID STEER (A62129)
2021 CATERPILLAR...
2017 Ford F-550 Ext. Cab Enclosed Service Truck (A61568)
2017 Ford F-550...
2004 JOHN DEERE 160C LC EXCAVATOR (A59823)
2004 JOHN DEERE...
2014 WESTERN STAR 4900 SF (A60736)
2014 WESTERN STAR...
