diy weed badger, In row cultivator, how?
   / diy weed badger, In row cultivator, how? #2
   / diy weed badger, In row cultivator, how? #3
*scratching head* i don't see point in it. seems costly, needing 2nd person to drive tractor / work unit.
you are working with "row / crop" stuff....
Everything Attachments | Skid Steer Attachments, Tractor Attachments, 3 Point Hitch Attachments, and Farm Tractor Implements. cultivators are made to set each individual tine to given row spaces. and you just drop it and go down the lines. as long as you are not driving tractor back and forth like you are drunk. ((not sure why anyone would drive back and forth on there crops anyhow)) it tills the area between each row. and in that removing weeds that would be growing within each row. pending on how good your row spacings are (assuming you planted with an actual multi row planter) your rows should be nice and predictable in spacing.
   / diy weed badger, In row cultivator, how? #4
They can make it cheaper by putting the weeder rotors directly onto the motors. These motors have quite sturdy bearings that are designed to take the load of a sprocket, so they can also take the weeding forces, the bending of the motor shaft instead of pure torsion.
It depends on the motor specification and type, but Danfoss has motors with slide bearings as well as roller bearings. Its just a matter of comparing spec sheets.
   / diy weed badger, In row cultivator, how? #5
Nice design. The 2nd operator can see exactly what is being weeded and adjust the position of the cultivator tines to exactly where they need to go, allowing removal of all the weeds without damaging the crop plants.
Looks like they used hydraulic motors, mounted to long shafts, which provides a long wheelbase for the bearings that support the cultivator wheels, which are overhung on the end of the shaft. Should be very sturdy.
TIGER 201 WELDER (A51248)
TIGER 201 WELDER...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
KUBOTA SVL97-2 SKID STEER (A51246)
KUBOTA SVL97-2...
