DIY Tractor implement dolly heavy duty 2400lbs
   / DIY Tractor implement dolly heavy duty 2400lbs #1
bottlediger
york, pa
none
   / DIY Tractor implement dolly heavy duty 2400lbs #2
Sorry, a couple of still photos would be just as informative, not a complex build. Glad you created a solution to make things easier for you.
   / DIY Tractor implement dolly heavy duty 2400lbs #3
Does the job :thumbsup:
   / DIY Tractor implement dolly heavy duty 2400lbs #4
Man... 20 mins of watching you build a pallet with wheels. I have to agree that pictures would have been sufficient on this one. I personally would have built the base with double-stacked overlapping lumber—no idea what this method is called but it definitely creates a stronger foundation. Adjustments.jpg
   / DIY Tractor implement dolly heavy duty 2400lbs #5
I used HF furniture dollies to build mine in 2013. Also built one for tiller, landrake, and phd, but I size them for each piece as I don’t have extra room in the shed.
   / DIY Tractor implement dolly heavy duty 2400lbs #6
All of the dollies I have built are the same basic design:
Works with the scarifiers down or up:
This one is rated at 4,000 pounds and is 8 feet long:
   / DIY Tractor implement dolly heavy duty 2400lbs #7
Pic of mine
Can’t get pic of front as it currently at a friend’s
(Sorry, no youtube)
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
JCB 532 Rough Terrain Forklift (A56857)
JCB 532 Rough...
