DIY replacing worn out gauge wheel assemblies Kubota F series
   / DIY replacing worn out gauge wheel assemblies Kubota F series #21
I see the bushings you mentioned (y)
The 4 lug hubs I bought has a 5” bolt circle & are for heavier implements they told me.
I guess that’s why the shaft is also bigger.
I also mow @ 3.5”
Anyways I’m excited to get it all built up & running soon
   / DIY replacing worn out gauge wheel assemblies Kubota F series #22
If the height adjustment was skipped it would allow the axle to be welded directly to the frame tube (or strut) end and eliminate the upper bushings & machining down the axles.
Simpler to make all new frame tubes and store the originals as is, but one big compromise.
IE. No gauge wheel height adjustment!
   / DIY replacing worn out gauge wheel assemblies Kubota F series #23
The OP threaded his shafts to lock them down tight with bolts.
   / DIY replacing worn out gauge wheel assemblies Kubota F series #24
Yes that's a good point, although he still had limited adjustment possibility but it does not sound like he was planning to change from 3.5" cut!
Since we have a Grasshopper mower where the height can be adjusted on the fly, I may just settle to have the F deck permanently set to 3.5".
   / DIY replacing worn out gauge wheel assemblies Kubota F series #25
@arto98607 are you wanting taller front deck tires for rougher ground like me
OR for less wear & tear on the components ?
   / DIY replacing worn out gauge wheel assemblies Kubota F series #26
Adjusting deck height on an F is not an easy or fun exercise, especially if needed often. Sometimes it’s nice to go from standard 3.5” to 5” to cut over roots. Of course you can lift the deck up to avoid striking them, but it’s nice to have a level cut.
   / DIY replacing worn out gauge wheel assemblies Kubota F series #27
For rough ground and also wet & soft ground since we need to mow some during winter. The small gauge wheels have tendency to dig into soft ground sometimes when having to reverse direction.
Wear has not been an issue so far, but for sure the small gauge wheels do not help.
   / DIY replacing worn out gauge wheel assemblies Kubota F series #28
It’s amazing how much taller & wider the fronts are on these ZD1211 & ZD1511 compared to most zero turns.
I think they’ll be fantastic on the front of this F mower (y)
   / DIY replacing worn out gauge wheel assemblies Kubota F series #29
These TINY Lil Ol 3.5x8.5” tube tires will never work here on my farm ground.
   / DIY replacing worn out gauge wheel assemblies Kubota F series #30
Wow what a difference when compared side by side!
My spindle kits came in yesterday and the shaft diameter is also 1-5/8", the new 15" wheels should be in couple of days.
2014 GALYEAN 180 BBL STEEL VACUUM TANK TRAILER (A52472)
2014 GALYEAN 180...
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
2019 HINO 195 16 FT BOX TRUCK WITH LIFT GATE (A52576)
2019 HINO 195 16...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
