DIY options=weekend of fun!
   / DIY options=weekend of fun! #1
moriboy
SW Oregon
Kubota M7040, L3901, KX057-4, JD 650G
I bought a pretty much bare bones M7040 last year during hay season, knowing full well that I would be adding some options down the road. At the time of purchase, we were in a hurry to get an additional haying tractor, so the one in stock at the dealer came home. Things have worked out for us this year, so I went on a bit of a shopping spree and now have the tractor outfitted how I want it. I had to order all of the parts which took about 3 weeks to get. I wanted to share with you all a quick summary of the install along with a few pictures. The total time to install this was about 6 hours. Here goes!
Here is a picture showing the new Anbo grapple. It's a 72 wide one. Although its a bit dirty, I really haven't had a chance to use it for more than 5 minutes. It's just to wet and muddy! First impressions are that it is going to be awesome for clearing brush and picking up/moving logs. The build quality is amazing as well. I do believe you get what you pay for, yes it was expensive..
To keep them rear wheels on the ground when I'm using that fancy grapple, I needed to add some weight to the rear. While I do have the tires filled I still believe you can't have too much ballast. Unfortunately when I bought this tractor, I was not able to get cast centers. So, I added 2 wheel weights to each wheel. That adds about 650 pounds total. I haven't had much in the grapple yet, but moving round bales on the steepest ground is very comfortable now.
In order to run the grapple (and my future post hole drill), I added the factory 3 function kit for the FEL. Installation was a breeze. Put the new handle on, bolt up a new valve body, add a couple new hoses, plug in a wiring harness, and you're done.
This picture is showing how the Kubota shock less ride system looks once installed. I move a lot of round bales, and our ground can be pretty bumpy. This system allows the loader to "float", absorbing most of the bounce. I can tell you it's amazing! You lose a little speed when raising or lowering the loader. Fortunately turning it on or off is simply done by turning the knob. I highly recommend this option if you want to take the bounce out of your ride. Installation was a little tricky since the instructions were terrible. You add quite a few new hoses and tee fittings. You also end up with a lot of extra parts, which add to the confusion.
In order to run our NH 216 rake, I need 2 remotes. I had one, but added the second one. Very simple process. Bolt the new remote on top of your current one, hook up a cable, and add the handle. I'm going to get a hydraulic tilt cylinder someday, so a 3rd remote is in my future as well.
Additional remote handle shown. I staggered them to allow for easier operation. Not sure yet if I like it that way. It's simple to adjust if needed.
   / DIY options=weekend of fun! #2
Nice tractor and grapple. You can never have enough hydraulic outlets.
   / DIY options=weekend of fun! #3
Really digging the boom suspension! Too bad it wasn't electrically actuated. Not sure about the low hanging hoses though?
Grapple control is a nice clean install too.
I still have to put the covers back on that house all of the hoses. I left the cover off for now so I could check for leaks and also to make sure I don't need to adjust hose angles. Electric activation is a neat idea.... It wouldn't be that hard to do.
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
Agri Metal Tuff Vac 5000 (A50774)
Agri Metal Tuff...
Deere 317G (A50120)
Deere 317G (A50120)
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2015 Dodge 5500 4X4 Bucket Truck (A52748)
2015 Dodge 5500...
Truck Bed (A50774)
Truck Bed (A50774)
