DIY fire pit
/ DIY fire pit
I like the ventilation hole design along the perimeter. I guess that's why its called a "Smokeless" fire pit?
Yes, the holes are supposed to make it smokeless. It seems that it works when the fire is really going, but starts to smoke more as it dies down.
/ DIY fire pit #23
Pjram - looks great.
I've been toying with the idea of building a "fire pit" in my suburban back yard. I've 4 large maples on the lot and they generate a lot of small limbs, plus there is all the cardboard from on-line shopping.
Sort of an upscale burn-barrel.
/ DIY fire pit #25
I just dug out a 20' circle, added gravel and some landscape bricks.
/ DIY fire pit #27
I have 50 acres, 50% is wooded. All I burn are the blow downs and I cannot keep up.
Yeah, just joking. I have 5 acres woods and only used downed trees and also cannot keep up. But some rotting logs are actually good for the forrest….👍
/ DIY fire pit #30
A friend used an old steel wheel barrow as his fire pit, could move it around while burning. I called it hell on wheels.
/ DIY fire pit #31
I burn a lot outside too.. mostly pine and everything I find along the property..
What I did for my pit is:
I used concrete “flower bed” boarders..8 straight (w 5 humps on each piece) and 8 curved pieces..
2 straight pieces on each side and 2 curved pieces on each end.. it makes a beautiful OBLONG pit..
I buried the 1st row 1/2 the width, in the ground..and set another row upside down into the 1st rows humps..
THEN I lined the bottom w 12x12 pavers..
Cleaning out is a breeze..
Simply remove the curved end boarder stones on one end and shovel the ashes into a wheelbarrow.. the bottom stones make finding the bottom very easy..
and the length and the height are perfect for larger limbs..
/ DIY fire pit #37
Thx. The basswood & Elm prob burn pretty quickly: prob not the hickory. Has to be some nice smelling fires
/ DIY fire pit #38
Maybe it's different where you live, but the biggest issue we have with smoke is that there's usually just enough of a breeze to push it towards you. Seems to shift direction so as to follow you wherever you sit. :(
/ DIY fire pit #39
should be recognizable from this group. best fire pit I've used so far!
/ DIY fire pit #40
Mine is rustic and simple. 3/8" thick steel ring, 42" diameter sunk 1/2 way into the ground by the edge of my woods. I burn anything too thick or gnarley to split. I supply the beer, bring your own camp chairs.
AGrotk 680 QA Drop Hammer (A64912)
AGrotk 680 QA Drop...
CEDARAPIDS HEAVY DUTY ROCK SORTER (A66734)
CEDARAPIDS HEAVY...
2010 Honda Civic Sedan (A66738)
2010 Honda Civic...
1995 Feather Lite (A64912)
1995 Feather Lite...
2006 SUPERLINE DO20T192ALP T/A 20FT TRAILER (A66091)
2006 SUPERLINE...
ATTENTION PLEASE READ (A64912)
ATTENTION PLEASE...
