DIY FEL mounted Brush cutter
   / DIY FEL mounted Brush cutter #1
HawkinsHollow
SE TN
Branson 3015R
I would love a lane shark, but it is just not in the budget right now. I saw this picture the other day and it got me thinking.
I think you could make a lane shark out of 1 or 2 lawn mowers that you attach to your forks on the FEL. The problem is a vertical shaft lawn mower would not work on its side so you would have to convert it to a horizontal shaft motor. If you had a big enough engine you could run 2 mowers or a riding mower deck with a bigger blade. Has anyone done this? I am intrigued. I am not talking about using this to clear the brush just to keep if from overgrowing the road like it tries to do this time of the year in the jungle. ( I mean southeast US).
   / DIY FEL mounted Brush cutter #2
I made a fel mounted hedge cutter, using sickle bar blades.
They're not strong enough, but work ok.
Mine will reach 10' high, extend 10' out to either side, and can cut horizontal / vertical right left forwards and backwards.
It was a lot of work to make, but fun.
I recently made new blade bars with opposed knives with a scissor like action, and it works really well now.
   / DIY FEL mounted Brush cutter #3
Hahaha.. Nice. Anything beats doing that by hand :)
   / DIY FEL mounted Brush cutter #4
I'll have to make a thread about it...
The number of hours I put into the machine rival hand cutting the hedge (well, maybe with a hand held power hedgecutter), but I'd rather spend an hour in my workshop than a half hour landscaping.
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
2024 Schulte 5026 Batwing Rotary Cutter (A56435)
2024 Schulte 5026...
CAT Chassis Only (A59076)
CAT Chassis Only...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
2015 FREIGHTLINER M2 BOX TRUCK (A58017)
2015 FREIGHTLINER...
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
