DIY bucket
   / DIY bucket #1
Takman
Bronze Member
Vermont
Old John Deere and new Takeuchi
I'm planning to build a 24" Scandi style bucket for my machine.
Just curious how you would go about bending the back plate/sheet metal?
   / DIY bucket #2
I made a 13" bucket for my homebuilt CADDigger years ago. To curve the 1/4" mild steel plate, I used 2 cable come-alongs and an O-A torch to heat it up a section at a time. As I bent it, I welded it to the side plates. Worked great.
24" is pretty wide. What I would do today is use a thinner carcass plate, 3/16 or even 1/8", and add wear plates to the outside of the curve. For yours, you could bend 2 pieces of plate, and weld them together in the middle. Wear plates can be a couple of inches wide, so they would be easy to bend.
   / DIY bucket #3
Agree with dfkrug. I made a skid plate for my haybine in a very similar manner. Take your time and do a nice job and you'll be pleased with your work. Or you could have a fabrication shop put a radius in it for you $$
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
7009 (A51691)
7009 (A51691)
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
2008 International 4400 Pumper Fire Truck (A50323)
2008 International...
