DIY a dying breed
/ DIY a dying breed #61
I think there is a "new" class of DIYers which falls between those who are and aren't.
The big box home improvement stores and TV shows have either created it, or encouraged it.
An awful lot of stuff that you used to have build, or even invent yourself, can now be bought off the shelf and bolted on.
Which allows people who really aren't DIYers to do some things themselves. Which isn't good or bad - it just is.
I have found that this all leads to a lot of people's houses having a similar look. It used to be, driving down a road, each house had its own style of mailbox post. Now, since HD and Lowes only sell one or two styles of posts for mailboxes, that's almost all you see. The unique, home-built post really stands out now.
With cars these days, the stuff you used to have to work on, you don't anymore (as mentioned earlier). With minimal maintenance, engines last longer than most people keep the car.
But you still need to do fluid changes, replace brakes, and various other mechanical tasks. And, even these are being geared toward the "buy it and bolt it on" person. On many modern cars, you now simply buy the entire wheel hub, all prepacked with grease.
/ DIY a dying breed #62
/ DIY a dying breed #65
</font><font color="blue" class="small">( It used to be, driving down a road, each house had its own style of mailbox post. Now, since HD and Lowes only sell one or two styles of posts for mailboxes, that's almost all you see. The unique, home-built post really stands out now.
)</font>
Wait until "mailbox baseball" hits your area and even the
$200 mailboxes won't stand up. Mine is now 70# of 1/8
steel plate (with Gambrel roof) and locking door. NOT incl
the 5" x .25" square steel tubing for the post. DIY of course.
Necessity is the mother of invention.
/ DIY a dying breed #66
)</font>
/ DIY a dying breed #67
For things I rely on I let the experts handle the work.
Example: the 2001 F150 gets serviced at the dealer's shop. Most of the time it's routine stuff and he mails me discount coupons for that type of work. Cheaper than I can do it myself considering the value of my time.
Had a 4-ton A/C installed in my new house last month. Could have done it myself, but decided to have it done by an expert.
Do the routine maintenance on my 2005 Kubota B7510HST (85 engine hours and counting). The warranty covers me for 2-3 years.
Paver block sidewalks- do it myself
Paver block patio -ditto
Salt box storage sheds- build it myself (see attachment)
Landscaping/irrigation - do it myself
Right now I'm getting ready to build a 25'x72' hay shed to store my accumulation of tractors, implements and other equipment. Fortunately, some previous owner in the distant past built the concrete foundation supports for a post frame building, but then decided not to construct the building (which my neighbor tells me was supposed to be a milking barn). Trying to find the right mix of DIY work and expert help for this project to keep the cost down.
/ DIY a dying breed #68
/ DIY a dying breed #69
You have nothing to lose by trying to fix it yourself, given some common sense. If you are going to toss something out you have nothing to lose by first taking it apart to see how it's put together. (The insides of a computer CD drive are incredible). Some things just can't be fixed these days but you never know until you look it over. Sometimes it's just a clip or spring that came loose, or some fuzz that is jamming a gear train. Broken drive belt? Think o-ring. You can't make a broken thing you were going to toss any worse by hacking at it.
/ DIY a dying breed #70
