Diverter valve mouting ideas.
   / Diverter valve mouting ideas. #1
ticolawnllc
Bronze Member
Bob Cat CT120
It's got my diverter valve. Can any one help out with mounting ideas.
I'm looking to mount on the loader arm. On a bobcat ct 120
   / Diverter valve mouting ideas. #3
Drill holes in the loader arm and tap them. Bolt it on and done.
Pay attention to the orientation and where your IN/OUT hoses are gonna go, and mount it logically.
Drill holes in the loader arm and tap them. Bolt it on and done. Pay attention to the orientation and where your IN/OUT hoses are gonna go, and mount it logically.
other than the in and out puts does the orientation mater.
   / Diverter valve mouting ideas. #5
Nope, a couple thousand pounds of hydraulic pressure will overcome gravity (14.65psi, roughly):D
Main thing with most diverters is their connections and coil need to either be somewhere NOTHING can get to them (most delicate part of the diverter) or else fab a protective cover, whichever is more practical...
You may find that the best way for hoses (if yours are like mine) is to use straight adapters from port (mine are SAE) to hose (mine are JIC) - this makes it easier to put angle adapters on so you can "point" your hoses where they lay better. Several of the diverters' ports are too close together to put 90's directly on the ports, because the 90's will interfere with each other when you try to tighten them... Steve
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2430 (A51248)
2430 (A51248)
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A53426)
2023 PETERBILT 579...
