diverter valve leak?
   / diverter valve leak? #1
swick1
Platinum Member
WV
John Deere 1026R
Is it normal for a diverter valve to slowly drip from the inactive work ports or do I need to get a new one? It drips about one drop every three seconds.
   / diverter valve leak? #2
I think you know the answer...no leaks are normal in hydraulics, but yet there always seems to be some minor seepage, at minimum. Active dripping like that indicates it needs to be tightened, re-sealed, or replaced.
This is the electric over hydraulic valve from surplus center that everyone gets for their grapples. Borscht style.
   / diverter valve leak? #4
Oh - hold on - I didn't read close enough. You mean that a little gets by the spool into the aux ports. I suspect that is very common. Plug the ports if for some reason you don't have capped lines attached to it.
Sorry about that.
   / diverter valve leak? #5
No, it's not normal.
   / diverter valve leak? #6
Some manufacturers have a 10 drop per minute limitation before replacement or repair.
You might call Surplus and see if there is a seal kit for that valve.
You might even take it apart and see if there is any visible debris on the seals or spool.
Thanks. I had the deere mechanic put it together. He may have not blown his hoses out fully when he crimped the ends.
2008 Ford F-350 Altec Service Truck (A50323)
2008 Ford F-350...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Cat DPL40 Forklift (NOT RUNNING) (A50774)
Cat DPL40 Forklift...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
Cat TH407C Telehandler (A52748)
Cat TH407C...
