diverter valve leak?
   / diverter valve leak? #1
swick1
Platinum Member
WV
John Deere 1026R
Is it normal for a diverter valve to slowly drip from the inactive work ports or do I need to get a new one? It drips about one drop every three seconds.
   / diverter valve leak? #2
I think you know the answer...no leaks are normal in hydraulics, but yet there always seems to be some minor seepage, at minimum. Active dripping like that indicates it needs to be tightened, re-sealed, or replaced.
This is the electric over hydraulic valve from surplus center that everyone gets for their grapples. Borscht style.
   / diverter valve leak? #4
Oh - hold on - I didn't read close enough. You mean that a little gets by the spool into the aux ports. I suspect that is very common. Plug the ports if for some reason you don't have capped lines attached to it.
Sorry about that.
   / diverter valve leak? #5
No, it's not normal.
   / diverter valve leak? #6
Some manufacturers have a 10 drop per minute limitation before replacement or repair.
You might call Surplus and see if there is a seal kit for that valve.
You might even take it apart and see if there is any visible debris on the seals or spool.
Thanks. I had the deere mechanic put it together. He may have not blown his hoses out fully when he crimped the ends.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
2005 JOHN DEERE 5205 TRACTOR (A51222)
2005 JOHN DEERE...
John Deere Quick Attach Pallet Forks (A50514)
John Deere Quick...
2013 John Deere 310SK (A47384)
2013 John Deere...
CAT ENGINE ( NON- RUNNER) (A50854)
CAT ENGINE ( NON-...
2012 Infiniti G25 (A50324)
2012 Infiniti G25...
