ditch witch 2310 no fuel
   / ditch witch 2310 no fuel #1
michael sealcoating
Ditchwitch 2310 trencher
i have a ditch witch 2310 that all of a sudden shut down and wont start. It has a half tank of fuel, i took all fuel lines off and blowed air through them, cleaned the fuel bowl thats on top of the tank install a new fuel filter, bypassed the fuel shut off valve, lift pump is working and its getting fuel but no fuel out of the injection pump. any help would be appreciated. It has always ran great but it just stoppped and shut down. so any help would be appreciated and if you know how to time the injection pump please let me know cause i have a feeling that ill be taking it apart.
   / ditch witch 2310 no fuel #2
If u could post a pic of the inj pump, it would be helpful..
If u shut it off w the key switch, u have a shut off solenoid by the inj pump.. make sure u hear it click or remove it from the engine..
Take the air cleaner off..
Hold the throttle wide open..
it wont let me upload the pics. Bosch injection pump
0 414 172 992
   / ditch witch 2310 no fuel #4
If it shut off on u and u kept trying to start it.. you now have air in the system..
There should be a hand primer or electric pump on the engine somewhere.??
Loosen the fuel inlet on the LAST pump.. now run the hand primer or electric pump until fuel comes out & tighten the banjo bolt.
Now loosen the steel lines from the inj pump AT THE INJECTORS..
Put the throttle on wide open and crank the engine until fuel squirts out of the loosened lines and tighten..
Now start the engine..
already did all that
   / ditch witch 2310 no fuel #6
Where r u at now.. still no fuel thru/out of injection pump.??
Do u have someone working on it.?
the engine was running and it just shut off, no it did not run out of fuel
reread my intital post
in ohio and im the one thats working on it
got fuel going to injection pump but no fuel coming out?
   / ditch witch 2310 no fuel #10
Is there any way to access the side of the inj pump.??
Sometimes there is the throttle plate that’s removable, that will give u access..usually held on by 4- 10mm bolts..
If u can access the pumps control rack, u can make sure it’s moving freely..
It sounds as if the shut off solenoid went bad, if it all of a sudden shut off while u were using it..
2013 Ford E450 Shuttle Bus (A53117)
2013 Ford E450...
John Deere BD1108 (A50123)
John Deere BD1108...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
Bobcat 22in. Excavator Bucket (A53117)
Bobcat 22in...
3 BATTERY CHARGERS (A53843)
3 BATTERY CHARGERS...
Vehicle Seats (A51695)
