Backhoe Ditch Witch 140 Backhoe mounted to 763 Bobcat
   / Ditch Witch 140 Backhoe mounted to 763 Bobcat #1
zybouirg
bridgeville pa
YM186
I have a Ditch Witch 140 Backhoe that I mounted to a Bobcat 763 Skid Steer.There are 3 Hoses coming off the Ditch Witch.I am guessing that 2 hoses are a return line and can be connected together however I am not sure what line is the pressure line and which are the returns.I have included a photo of the hydraulic manifold on the Ditch Witch.Also I do not know what is the high pressure connection on the Bobcat.Top or Bottom.
Thanks
412 292 5183
   / Ditch Witch 140 Backhoe mounted to 763 Bobcat #2
I answered your Ditch Witch connection question in the Hydraulics Thread.
I think you need a manual for the skid steer also.
The connections should be like my V417, they are both pressure or return depending which way the constant flow valve is activated.
I can spin the brush hog in either direction, the blades are sharpened on both edges.
Closeup of the flat face aux hydraulic connectors on the boom.
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
1992 Ingersoll Rand 185 185CFM Towable Air Compressor (A55973)
1992 Ingersoll...
LOT: Uline 72" Rolling Staircase, 6' Fiberglass Stepladder (A59076)
LOT: Uline 72"...
BUSH HOG DISC (A58214)
2019 TAKEUCHI TL10V2 SKID STEER (A52709)
2019 TAKEUCHI...
