Ditch digging tool complete
/ Ditch digging tool complete #1
Paddy
Bloomington, IN
Kubota, G5200, KAMA 454
New post here to show the new attachment. I had some 6" wide 1/4" plate laying around. I welded three together to get a total 18" wide. The outer two are cut at 45 deg to get the ditch shape. On the lower 6" I bent it forward 45 dep to help it pull itself down.
First shot
Here is a back view. I reenforced the blade with an additional 6x1/4 plate forming a triangle. Then I welded some 1 1/2 x 1/4 to stiffen it.
And last, the ditch! I did have to add weight, 4 5-gal buckets of gravel. Since I used the grader blade frame, I have the angle adjustment. I might add a small blade to direct the dirt a little farther from the ditch
Patrick
/ Ditch digging tool complete #4
That's a fine looking ditch. I envisioned the terrain to be much steeper and rockier for some reason. Nice job.
The photo just does not get the slope, 30+ percent. The ditch on the other side yieled several limestone pc as large a concrete blocks and bounced over some very large stuff.
My drive is long 600-700 ft. It goes down a steep slope to a creek and then back up to the house site. So I have hills coming and going!
/ Ditch digging tool complete #6
</font><font color="blue" class="small">( That's a fine looking ditch. I envisioned the terrain to be much steeper and rockier for some reason. Nice job. )</font>
Aw Jim, you're just used to Vermont where everything is steep and rocky!
/forums/images/graemlins/smile.gif
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
SWINGTEC D-88307 COLD FOGGING APPLICATOR (A64276)
SWINGTEC D-88307...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2021 Chevrolet Silverado 2500 HD Royal Service Truck (A64194)
2021 Chevrolet...
(2) Lexion 7564961 Sieves and (3) 7574411 Grates (A65640)
(2) Lexion 7564961...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
