distributor cap tracking
   / distributor cap tracking #1
Bandit2026
Ferrum, VA
Ford 8N, Kioti CK35
My faithful ol 8n has died on me again. Having had this problem several months ago and after much help from this forum it ran like new. Problem was traced to tracking in distributor cap. Now it has happened again after only about 2 hours run time. Any ideas why??
   / distributor cap tracking #2
Tracking or cracking?
If tracking, I don't know what that means.
If cracking, it's likely caused by the axle center pin and bushing being completely worn out and allowing the axle to come up and bust the distributer cap.
The fix is to renew the pin and bushing.
This assumes you have a front mount distributer and not a side mount.
It is a front mount distributer and I call it tracking the rotor is firing off to one side of the cap causing a carbon buildup and not sending spark through the cap.
   / distributor cap tracking #4
tracking is usually the result of incorrect points gap or timing way off, if carb is running lean on fuel that will cause it as well
   / distributor cap tracking #5
may want to also chk the upper bushing in the dist for wear
Might be the dirty cap, have a new one in hand. Pretty sure its not moisture as it sits inside always. How would a lean mixture cause this???
   / distributor cap tracking #7
I would also like to know how/why lean mixture would cause tracking. Make sure you have correct resistor if one is recommended for coil being used. If tractor has been converted to 12 volts,it definatly need's a resistor with 6 volt coil.
If you go back to 2-9-18 you will see the same problem that I'm having now. Tractor running fine when parked in barn then all of a sudden for no reason it will not run. Turns over good getting gas but no fire to the plugs. I can't imagine what could happen to it just sitting in the barn out of the weather after running so well.
   / distributor cap tracking #9
Are you running copper core wires or the automotive carbon core wires. These older tractors should have the metal core wires.
Yes they are medal core
2008 Toyota Tundra Crew Cab Pickup Truck (A51692)
2008 Toyota Tundra...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
2005 Carolina Skiff 21DLX 21FT. Boat with 23FT T/A Boat Trailer (A51694)
2005 Carolina...
25"x 10" Kubota RTV-X1140 (A52377)
25"x 10" Kubota...
Air Exchange rotary screw air compressors (A53117)
Air Exchange...
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
