Dissatisfied with 2030.
   / Dissatisfied with 2030. #1
jacob59
Bronze Member
Tebbetts, Mo.
LS 2030, 9N, Ford 4600,
Annoyed
Just broke 50hrs on my 2014 2030. Don't use it much. When I do and need too battery is dead. My 1948 6 volt 9n can sit for a entire season and fires up every time. Cheap battery.
Jack
   / Dissatisfied with 2030. #2
I wouldn't condemn the tractor because of a bad battery, Stuff happens. Unless something is wrong on the tractor that caused it to go bad.
Besides, I would wager that almost every tractor has something go wrong with it in the first 100 hours.
Your right of course, but it still pisses me off.
Jack
   / Dissatisfied with 2030. #4
All kinds of electronics on new tractors, which consume a trickle of current whether the tractor is running or shut down.
Guess I'm going have to get a trickle charger.
Thks Jack
   / Dissatisfied with 2030. #6
One of those solar powered 'battery maintainer' thingys will do the trick. I've now had to hook my ute up to one 'cause, being retired, I don't run it everyday and if 3-4 days go by the various security systems leech enough power from the battery that only a battery charger can save it. No worries since I started using the maintainer.
   / Dissatisfied with 2030. #7
Take the battery and have it load tested. I've seen new equipment come through with defective batteries. Should be a warranty item.
Thanks, I'll do that.
Jack
   / Dissatisfied with 2030. #9
Did you test the battery? If the battery is good, I would take it back for a warranty claim because something is drawing power when it shouldn't. I bought a 2023 and had a muffler crack and a differential lock go out on mine. That's what you pay forbade warranty for. As far the battery, I keep everything I own on a battery tender, mostly during the offseason. I attach a pigtail lead to the battery and leave the plug accessible somewhere outside the machine for easy plugging and unplugging. I have one on my LS, my UTV, and my zero turn.
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
AUCTION STARTS HERE @ 9AM (A51242)
AUCTION STARTS...
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
WASTE OIL TANK (A50854)
WASTE OIL TANK...
