Disk = Harrow? What do you call a disk?
/ Disk = Harrow? What do you call a disk? #21
There are disc harrows and disc plows.............they look a lot alike, but, they do different things.
A "harrow" be it spring, spike or disc is designed to break-up rough tillled ground, busting clods, clumps, and smooth gouges. It is not a tillage piece but rather a conditioning tool.
Plows? There are disc plows which are heavier which are intended as the primary tillage tool that bust new ground and attempt to condition in the same pass.
/ Disk = Harrow? What do you call a disk? #22
Disc works much better in soil with plant debris and/or numerous rocks.
/ Disk = Harrow? What do you call a disk? #23
Mickey_Fx said:
Take a look over in the Yanmar forum for a thread on pto speed. Just posted a couple pics with a tiller in action and what soil looked like afterwards. A disk will not produce this kind of results.
This was an old post of mine about tilling depth with a CCM tiller. This is how my soil looked after tilling. Jay
/ Disk = Harrow? What do you call a disk? #24
[/ATTACH]Disk picturesCoverDisc3378.jpg
/ Disk = Harrow? What do you call a disk? #25
bx23barry said:
I had never heard disc and harrow used together until I found this board and I have been around farming all my life. Around here discs are primary tillage implements. I have seldom seen a plow being used. I think we have different conditions and terminology here in the valley than most the rest of the country.
Here is a link to the Land Pride site - they are selling a combo unit for, I guess, pasture renovation.
Land Pride DRG Series Drag Harrows
/ Disk = Harrow? What do you call a disk? #26
Nice disk Hugh. I really like those Tuf-Lines. They look to be a notch above the rest.
But, you didn't put any text in your post.....maybe you're adding a second post as I type this one. I think I get the point of the pictures though. With my new disk I could not get it set up so that the outside rear disks would not leave a deep furrow. I tried several angles and even changed the location of the disks along the rear gang.
I'm assuming the device in your pictures is a disk for covering that furrow.
So, does it work? If so, where did you get it? How does it attach? How much did it cost?
And I guess the last question is does it matter if the rear outside disk leaves a furrow. It aint pretty, but is it really a problem?
/ Disk = Harrow? What do you call a disk? #27
I am a rookie but my neighbor who grew up with C model Allis Chamers and now has a Ford Jubile just disc up his field nice and level. He uses a 2 disc plow. I will try to get some pictures as it is an interesting set up. It has 2 wheels that look like railroad wheels then disc with a standard looking disc pict included. He says the secret is using a mild angle make sure front and rear gangs are level and don't disc deeply. Usually I do the opposite and is why I get the deep furrows.
The picture with the deep furrows was before I had the cover disc. I will try to get some new disc pictures.
/ Disk = Harrow? What do you call a disk? #28
There is such a thing as a disk plow. Sounds like what you are describing. But as I understand it, a disk plow is a plow, not a harrow.
Here is a pic:
Hugh, where did you get that cover disk? Is it just for Tuf-Line disks?
/ Disk = Harrow? What do you call a disk? #29
GEORGE
The pict you posted is what my neighbor pulls witold Jubile but his set up is massive.
If the end of the rear disc has a knob, the cover disc can be attached. I ordered it from Wendall at Wilson Tractor, Newberry SC
/ Disk = Harrow? What do you call a disk? #30
Thanks. I'll check mine out.
/ Disk = Harrow? What do you call a disk? #31
Farmwithjunk said:
There's "the definition" and then there's "what everyone calls them". Around here a disc is a disc. A harrow is something you generally drag BEHIND the disc. Call a disc a harrow or a disc harrow and farmers from this area will look at you like you're a bit strange. In fact, you won't find too many older farmers that say "harrow" . Around these parts, it's pronounced "har-ee". But then again, we're all a bunch of hillbillies ;)
There are several for tractors. I've been around tractors all my life, but once poking around here I had to look up what a rotary cutter was? A bushhog. Or a shredder.
I call it a disc. In Mississippi the drag harrow we just called a drag. It had the spikes in the back but in the front it had a metal paddle wheel (picture a boats paddle wheel). I guess this was meant to chop it the opposite way the disc cut it.
Even your term Hillbilly has a different origin. To long to type, read it here..
Hillbilly - Wikipedia, the free encyclopedia
/ Disk = Harrow? What do you call a disk? #32
Those of us who're right proud to be thought of as "hillbillies" know what it means, Wikipedia or no!
PROUD AMERICANS THAT ARE TOTALLY SECURE WITH WHO THEY ARE AND WHERE THEY COME FROM.
Some call us rednecks. That's OK by me too.
I'll be out'n the back 40, disc'n.
